What's the life of the stock clutch?
Old Apr 17, 2003 | 03:46 PM
THEKNITE's Avatar
I'm almost at 30K miles, and my clutch feels like it's catching at the last inch. I was wondering if anyone's clutch died already, what are the symptoms, how much did it cost, and how long should it last for? I'm an experienced driver so I never really burn the clutch and I'm rerely in traffic.
Oh, and besides, should I go for the 30K mile tune up? what's included?
thnx max lovers
Old Apr 17, 2003 | 03:55 PM
studman's Avatar
I'd say 15,000 miles, since I've already been through 2 of them and am on my third now.
Honestly, it depends on where you drive, how you drive, and the weather. If you drive in bumper-to-bumper traffic in Arizona and you like to race your car, it won't last nearly as long as if you drove on the highway in Maine and you drive like a grandma.
Old Apr 17, 2003 | 04:06 PM
THEKNITE's Avatar
Clutch
Well, there is a huge gray area between racing and driving like grandma. I love to step on it, and push it to the limits, but as long as you use the clutch correctly, I dont' see why would it wear out faster.
Anyway, were the new clutches under 36K warranty?? or did you have to pay?
thnx for the info
Old Apr 17, 2003 | 04:09 PM
max2k1SE's Avatar
Re: Clutch
thnx for the info
AFAIK, any wear-and-tear items are not covered in the warranty - like tires for eg.
No idea about clutches - i would say unless this is abnormal, it won't be covered - hope someone has some experience in this
Old Apr 17, 2003 | 04:22 PM
studman's Avatar
You're right, but you're wrong too. Both times the clutch was replaced without charge under warranty. Basically what happened was that the clutch would slip in cold weather when the engine was cold, causing a "burrrrruurrrrrurrrrphhhhh" sound. The sound was similar to a locked brake caliper. So they gave me a little hassle (the typical "stupid-driver" routine), but they fixed it both times. It appears that the clutch had a TSB out on it. But the TSB didn't come out until after I had already been through the first one and was on my second one. So when the second one started acting up, I used the TSB to get it replaced.
Funny how it is... I tend to get everything fixed once BEFORE the TSB is released, and then I have to go back in for the TSB. This happened to my MAF, my clutch, and my Bose radio. Wonder what'll break next?!!!
Old Apr 17, 2003 | 04:30 PM
njmaxseltd's Avatar
Every 5 speed I've owned went over 100,000 miles on the original clutch. My old Prelude SI went 135,000 on the original clutch. If you drive a stick shift correctly, there's no reason not to get 100,000 miles out of your clutch.
Those who hit the track will chew up a clutch quickly.
Old Apr 17, 2003 | 04:49 PM
RT03SE's Avatar
Clutch life expectancy
Too early to relate data regarding my 2k3 MT, but I had over 150,000 on my Pathfinder and I often used that clutch to brake. Had original front brake pads and clutch when I sold it.
Hoping the Maxima will echo those results.
Old Apr 17, 2003 | 04:57 PM
max2k1SE's Avatar
Dude - let me know what you get fixed next - I'll wait for the TSB
Old Apr 17, 2003 | 06:48 PM
2k2PhatMax's Avatar
Sold 2 99Silvermist SE :)
if its a 2k2 2k3 and ur at the track i cant see how the clutch would be effected that much due to no one want to spin therefore there are not any hard clutch drops??? am i right ?
Old Apr 17, 2003 | 06:55 PM
2k2PhatMax's Avatar
Old Apr 17, 2003 | 07:20 PM
2K2_6spd's Avatar
Should last 100k+ with normal useage.
Old Apr 17, 2003 | 07:59 PM
THEKNITE's Avatar
clutch
I was hoping for answer like this. My previous car Probe GT, had 70K highway miles when i bought it, and lasted till 133K until i sold it.
Hope my Max will do just as good.
thnx for the input guys
be good
Old Apr 17, 2003 | 10:51 PM
biggmax
Re: Clutch life expectancy
Front brake pads that lasted 150,000 miles on an SUV? C'mon... You must have meant original front lug nuts.
Old Apr 18, 2003 | 01:16 PM
Galo's Avatar
Maxima Pilot
Wow. Clutch on my Gen4 lasted 80k miles,
all other clutches I've had lasted well over 60k miles...you be a clutch terror!
9aj9
Apr 5, 2020 12:11 AM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
