Grinding noise under the hood...
Old Apr 22, 2003 | 08:47 AM
nice95GLE's Avatar
When I put my car in reverse and step on the gas I get a grinding noise from under the hood on the Pass side. I remember reading a while ago that the strut bar causes something to grind against it in reverse. But I checked and everything looks like it clears the bar pretty good. Anyone having this problem?
Nice
Old Apr 22, 2003 | 08:49 AM
Young04's Avatar
Re: Grinding noise under the hood...
Nice
it's likely your FTSB not clearing the manifold. i had the same problem as you did (only in reverse and when i hit the gas). go buy 18 washers from home depot and put three under each of the bolts. problem was solved for me.
hope this helps.
Old Apr 22, 2003 | 08:50 AM
Phoenix1911's Avatar
Maybe you shouldn't be tromping the gas in reverse!? j/k!
The motor torques the opposite way in reverse so its probably your strut bar.. Try putting some 1/2" washers on the bar to change the clearance... Don't go to high or you hit the hood of course...
Old Apr 22, 2003 | 08:54 AM
nice95GLE's Avatar
Thanks, will do
Old Apr 22, 2003 | 03:26 PM
Virus's Avatar
It's the FSTB. When you put it in reverse the engine raises a good distance. Just don't go backwards fast and it'll be fine.
Old Apr 22, 2003 | 03:29 PM
krmaxima's Avatar
u put 3 washer under each bolt how in hell did u clear the hood????? i have only one washer and it still makes the noise but it touches the hood???? barely
Old Apr 22, 2003 | 03:37 PM
Young04's Avatar
i have the BOMZ, just fyi, in case it's relevant. are there different thicknesses of washers? mine are very thin.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
