dual exhaust
Old Apr 24, 2003 | 09:22 AM
MaxinOutSE's Avatar
dual exhaust
Is it possible to put a dual exhaust on a 2k2? If so does anyone have any pics of it?
Old Apr 24, 2003 | 09:24 AM
255HP_03_SE's Avatar
Re: dual exhaust
WHY? The Max performs quite well without it. And you have to be careful with changing the configuration of your exhaust.
Did you notice, however, that the new 2004 Max has duals?
Old Apr 24, 2003 | 09:26 AM
jjs's Avatar
jjs
In addition to routing problems (I think someone either tried this or looked into it and found that the spare tire well needed to go or otherwise have modifications to get the drivers side pipes to route throught the area. Also, look at your rear bumper...it will be lopsided since the OEM exhaust 'cutout' does not exist on the driver's side.
Old Apr 24, 2003 | 09:37 AM
thrasher's Avatar
the main problem is that the fuel systems are located right where the exhaust would go through to the bumper. so no go due to fire hazard. it would be possible, i suppose, if you wanted to get rid of the spare tire well, but it would still be a tight squeeze. i have talked to a bunch of different shops, and none of them could come up with a way to do it besided cutting through the tire well.
Old Apr 24, 2003 | 09:42 AM
MaxinOutSE's Avatar
Re: Re: dual exhaust
i think the 2k2 would look more aggressive with a dual exhaust system.
Apr 16, 2020 05:15 AM
bigdogsteve
Jan 31, 2018 04:18 PM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
