Brake Judder
Brake Judder
I had the notorious brake trouble with brake judder after only 20k so instead of going through the endless cycle of re-surfacing, I opted to replace the front rotors with Stillen drilled rotors and metal matrix pads. The brakes work great now and there is no judder, but there is a noticeable whirring noice when stopping. Is this normal to expierence with drilled rotors? What is the maintenence like on the drilled rotors? Can they be resurfaced like stock rotors if needed? Any info will help.
Re: Brake Judder
I also have the same rotors/pads. Yes, there is some whirring noise when braking. BTW.... Brake Judder is back after 30+k. As someone who on other cars routinely got 100+k out of a set of rotors/pads, not sure what I am going to do next.
Re: Re: Brake Judder
Re: Re: Re: Brake Judder
Check out my old post on this...Warped Rotors, I've had a nightmare with brakes, I've learned alot about cars through!
I have only had problems with my front w/60K my rears are still stock!
I will be resurfacing my XDrilled (2nd Cut) and my stock rear rotors (1st cut), soon as well as installing Raybestos Ceramic pads both front and rear.
If you read my post I'm wondering if it's something else besides driving style/ Nissan OEM Rotors and Pads, etc.....Calipers?
Good luck
Robert
Good luck
Robert
Re: Re: Re: Re: Brake Judder
Good luck
Robert
Good luck
Robert
Apr 16, 2020 05:15 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
