Problem removing oil filter
Old Apr 27, 2003 | 12:44 PM
KP ROX's Avatar
Hey,
I'm trying to pull off the oil filter using an oil filter cap wrench, but the wrench is not gripping the filter. I've got the right wrench, which worked just fine the last oil change, but it just won't grab the filter the time (it slides around the filter). Anybody know of any other alternatives to the wrench (obviously hand turning doesn't work). Thanks.
Old Apr 27, 2003 | 12:50 PM
jonbth's Avatar
Use a band wrench that goes around the body of the filter, you get a better grip and can get closer to the threads for more torque. Also. be sure you're turning it the right way, it's easy to turn it the wrong way when lying underneath a car.
Old Apr 27, 2003 | 12:58 PM
KP ROX's Avatar
I haven't seen any band wrench small enough to fit tightly around the filter.
Old Apr 27, 2003 | 01:33 PM
sascuderi's Avatar
When this happens to me I tape sandpaper inside the oil wrench to get a better grip on the oil filter. Try that.
Old Apr 27, 2003 | 01:36 PM
jonbth's Avatar
Better parts stores carry them. I use one made by KD tools. It's really small and fits tightly.
Old Apr 27, 2003 | 01:37 PM
boo's Avatar
boo
I had the same prob on my 97. I tried a band wrench made
by alltrade (package comes in two sizes). It worked
perfectly on the small filter. I have no idea where it
was purchased because I received it as a gift. I'm about
to change the oil on my wifes 03 so I'll see how it goes.(first
oil change).
boo
Old Apr 27, 2003 | 01:59 PM
Y2KSESteve's Avatar
A big set of channel locks gets my filter off every time.
Old Apr 27, 2003 | 02:37 PM
HitManSE's Avatar
Use a sledge hammer and a chisel.
Old Apr 27, 2003 | 03:34 PM
BigFly_2K2SE's Avatar
Since you're throwing it out, just punch a screwdriver into the side and turn it with that.
Old Apr 27, 2003 | 07:18 PM
kratz74's Avatar
Believe it or not he's not kidding. This does work. Maybe you need to buy the kind of oil filter wrench than i slike a pair of scissor with teeth on the inside. I've never had an oil filter NOT come off with these. Get the samller version (there are usually 2 sizes in the store). Tha Max filter is kinda puny.
Old Apr 27, 2003 | 07:46 PM
KP ROX's Avatar
Re: Problem removing oil filter
Hey,
Thanks for all the help. I found some sticky adhesive tape and applied it to the filter to stop the cap wrench from sliding. And what do you know, it came off. Sometimes it pays to use your brain.
Old Apr 27, 2003 | 08:32 PM
AKM2k5's Avatar
Re: Re: Problem removing oil filter
Brains? Ha!! I just beat the **** out of everything. if I want to but i sandwhich in half, i used a hammer. If i want to turn on the water.. i use a hammer. When i want to open the car window.. i use a hammer... went i want to pee.. I use my hands and flush with a hammer. No brains for me!
Old Apr 27, 2003 | 09:21 PM
klee215's Avatar
sctludwig
Sep 1, 2022 01:32 PM
The Frye
Sep 2, 2021 11:03 AM
kjlouis
Oct 3, 2015 05:29 AM
Pnjboyzz
Sep 4, 2015 09:04 AM
sdotcarter
Sep 2, 2015 09:53 PM
