Noise at Startup
Old Apr 27, 2003 | 04:25 PM
mtjoy's Avatar
Noise at Startup
When my 2k3 sits for several days and I start it up, as the engine fires I hear kind of a grinding or vibrating noise for 1-2 seconds and it goes away. This is only when the car is cold and it has been sitting for several days. Anyone else heard of this?
Old Apr 27, 2003 | 05:10 PM
255HP_03_SE's Avatar
Re: Noise at Startup
No... and why haven't you run it up to the dealer yet?
Old Apr 27, 2003 | 05:24 PM
Y2K2Driver's Avatar
You may be hearing the timing chain tensioner before it gets oiled up. I know I often hear something right after the engine is started cold and I remember someone here saying it was just that and considered normal.
Old Apr 27, 2003 | 05:55 PM
WHEELMAN_03_SE's Avatar
Yeah mine does this too as it is not a daily driver but rather a weekend toy so it doesnt get run much during the week i find that it only does it if i leave it sitting for more than a day. also it is worse if i forget to slip it into neutral before i crank it.
WHEELMAN
Old Apr 27, 2003 | 09:21 PM
bobcat's Avatar
Glad I'm not the only one this happens to. I never took it to the dealer since I'd probably have to leave it overnight for them to hear it in the morning. Besides, once the temps warmed up it hasn't done it so..
Old Apr 28, 2003 | 09:25 AM
Phoenix1911's Avatar
Its your starter and it seems to be a Nissan thing! Something about dried grease and bearings??? I've never seen a starter with either but thats what I've heard... Mine does it to, esp when its cold out..
Old Apr 28, 2003 | 09:48 AM
MaximaDisciple's Avatar
You're correct. Your Maxima has a timing chain instead of a belt for durability reasons. On inital startup you'll hear that "grinding" noise which is a "normal" occurance on our Maximas. Not exactly sure why it does, but I wouldn't worry about it.
Old Apr 30, 2003 | 11:34 PM
ynot411's Avatar
It's about time I found out what the situation was. I'm glad that I'm not the only one.
Old Apr 30, 2003 | 11:49 PM
E55AMG2's Avatar
Wat
bump
Old May 1, 2003 | 12:10 AM
maximadave's Avatar
detailerdaveb@gmail.com
same thing here if my car sits for a while
Old May 1, 2003 | 12:48 AM
ynot411's Avatar
Does anyone know what to do to fix the problem? It can't be a good thing if it keeps making the noise everytime you start the car first thing in the day. No Nissan mechanics out there?
Old May 1, 2003 | 06:32 AM
Larry's Avatar
Re: Re: Noise at Startup
If you want to leave it over night for them to tell you "checks out ok" and get it back with dings and scratches then by all means take it to the dealer. I would avoid the dealer if you can!
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
