Sweet mother of mystery
Old Apr 27, 2003 | 07:29 PM
GrkMchn's Avatar
I got a 2k2 6 spd and when going from a complete stop only it makes a high pitched like noise from the driver side front wheel
Old Apr 27, 2003 | 07:39 PM
Uconn411's Avatar
Bad wheel bearing? Maybe caliper not releasing right?
Old Apr 27, 2003 | 07:59 PM
Maxmann's Avatar
don't know if it is the same but I had a howling noise when going from a stopped position in 1st gear and there ended up being a problem with the clutch plate and there is a TSB on this for 2k2 Maxima and Altimas with manual transmission. You could be having this problem. Very much a rubbing/howling noise. Scan some old threads or better yet search the TSB sticky thread. You'll find it there. Good luck. They repaired mine and so far it is just fine.
srm
Old Apr 27, 2003 | 08:09 PM
GrkMchn's Avatar
tsb?
Old Apr 27, 2003 | 08:40 PM
WHEELMAN_03_SE's Avatar
Originally posted by GrkMchn
tsb?
i had the same question it stands for Technical Service Bulliten you should see the tread on here about the fourth or fifth one down from the top
WHEELMAN
Max139617
Oct 19, 2016 11:34 AM
Balkins
Aug 12, 2015 06:39 AM
