radio help
radio help
I have a 2k2 with out the bose radio, what I wont to do is install a sub and an amp but I wont to keep the factoy radio, I know that the factory radio has no outs to connect the amp if i get a line level output will that work? if not what do i do thanks for the help.
Good question. I want to keep mine as well. Were I'm from if they see a hot deck they will break your window and rip up your interior dash, and I will lose the steering wheel controls, which I like. So someone help us!!!!
look in the audio forums but basically you can tap into the speaker wires and then runs the wires into either to an amp if that amp takes a speaker level inputs or through a converter that takes your speaker level inputs to convert that to a low level RCA input.
Then you needs to run a power wire (at least 4 or 8 gauge from the battery), a ground wire (short wire some thing metal), and a remote turn on wire (which you need to tap into an accessories wire that only turns on if the key is turned). It's not too hard if you take your time and do a lot of research.
May be somebody with search option can post the link to a more detailed how-to. Good luck.
The info you need should be in here:
http://members.lycos.co.uk/LucyLu112/
Download the files that you want from my ftp site, and then change their extension from .jpg to .rar
BTW, if they are already .pdf or .doc, don't change them.
Download Winrar from here if you don't already have it: http://www.rarlab.com/rar/wrar32b3.exe
Extract and enjoy the .pdfs!!! Please don't delete the files so that others can have them.
Other pages that should help:
http://carstereohelp.com/stereoremovalNisMax3.htm
Steering Wheel Radio Control Interface
http://www.crutchfield.com/S-4qZFl1q...0&I=127SWIX+++
mikeg75
Nov 30, 2015 05:12 PM
