Engine rattle
Old May 5, 2003 | 08:19 PM
CCNY's Avatar
Engine rattle
I've been hearing a very subtle rattle lately from under the hood (I think) when I start from a full stop. Happens a little bit when I rev the engine in neutral as well. The sound is kinda like a rattlesnake's rattle but slower and a bit deeper. I drive an automatic 2k3 with 9K miles.
Anybody else experience this? It's irritating especially since the engine was sooo smooth before.
Old May 5, 2003 | 08:27 PM
Maxman2000's Avatar
If you got a front strut bar.. it's might be hitting the intake manifod. I have a rattle to on my 2k SE. I think it's a heatshield loose some where. I had a loose catalitic converter heat shield on my 3rd gen once and it sounded the same as now.
Old May 5, 2003 | 09:06 PM
CCNY's Avatar
I do have an SE...If it's the strut bar, how can I tell and what can I do about it?
Old May 5, 2003 | 09:17 PM
Maxman2000's Avatar
Put 3 thin washers on each stud so that you raise the strut bar a little. After doing that make sure it doesn't hit the hood. I don't garentee that will fix the ratteling but it worked for the people that did it. From what you described when you rev the engine and when you start the engine, the engine moves back and forth, and when it does that, it has a tendency to touch the strut bar.
Old May 5, 2003 | 09:32 PM
CCNY's Avatar
Thanks, I'll try it.
Socalstillen
Sep 20, 2015 11:46 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
