rear clear sides bulb color?
Re: rear clear sides bulb color?
Originally posted by kim114
What color of bulb should I use for the rear clear sides? Do I have to use the stock ones, or could I use white bulbs for the back, also? Thanks!
Here's a hint... there was a great writeup about how clears are against the law in all states. Serious. However, MOST of the time, law enforcement will probably not mess with you (unless you are driving bad or have other 'obvious' mods)...
so in my case, I have orange bulbs that came with the front clears and red bulbs (purchased at Walmart) for the rear clears... this makes it less obvious to law enforcement... during the day, they could probably care less... during the evening, with white bulbs in the clears, you'll get a bit more attention than normal IMHO.
_R
_R
_R
_R
Someone in here posted that they got a ticket for polargs in the sides.
you can get red LED's at www.midnightmoose.com they don't fade like bulbs and are the right color, red, not pink. also, doese anyone know where to get amber LED's for the front the clears? the amber bulbs that come with don't look good with the red LED's I have in the rear
Both the front and the back clear markers use 194 bulbs. You can get them anywhere...Autozone, Pep Boys, etc. Each set of 2 was around 3 bucks when I got them. These aren't the bright LED ones though, they're just regular red and amber (the red looks a little pinkish at night).
tkostiuk4...you can get amber LED bulbs from http://autolumination.com/leds.html
Or do a Google search for "LED 194 bulbs" and you'll get tons of results.
vingodine
45
05-21-2016 12:46 PM
Huttig2009
09-25-2015 03:31 PM
