lowering my car...what else is needed??
Old May 8, 2003 | 11:41 PM
vsmax's Avatar
hey guys,
just bought OBX coilovers...bought them cheap so i dont care if they dont ride well....
my question is...what else is need when doing a coil over system like mine... i have
4 springs
4 seats
4 sleeves
do i really need to change anything else on my carf..
my friends who are acu and honda guys told me i should cange my chamber somthing or another...
do i really need to?
thanks guys
vishaal
Old May 8, 2003 | 11:43 PM
Maximam's Avatar
Alignment
Old May 9, 2003 | 12:19 AM
limsandy's Avatar
Re: lowering my car...what else is needed??
thanks guys
vishaal
It's called camber kits/bolts. Sometimes, you need them, sometimes you dont. Check with your local import shop.
~limsandy
Old May 9, 2003 | 01:11 AM
clipse's Avatar
Get some aftermarket shocks otherwise you'll be sorry later on and wish that you did.
Old May 9, 2003 | 04:19 AM
PCGuRu2K's Avatar
If you don't lower it more then 2" then you won't need camber plates. Just an alighnment after the springs settle in will be good enough.
Be prepared to here a lot of clicking and spring noise with the obx if you drop it low.
Old May 9, 2003 | 09:48 AM
vsmax's Avatar
imlanning on dropping it low like 2-2.5 .....
why would i hear clicking and spring noise...
and why would i need aftermarket shocks...are they REALLY needed?
thanks vishaal
Old May 9, 2003 | 12:50 PM
NJMAX2KSE's Avatar
S_H_I_F_T_
coilovers huh.. get rid of them.. you will need a new struts a camber kit numerous alignments and lotttts of new tires sooner than later.. im taking mine out after the summer probally gonna get the tien springs
Old May 10, 2003 | 08:38 AM
clipse's Avatar
thanks vishaal
-If your planning to lower your ride around 2-2.5 inches all-around I suggest you get either get PROGRESS Sport Springs or TEIN S-Tech Springs or a "TRUE" coilover system (Ex:JIC,TEIN,or PROGRESS)
-You'd here clicking/misc. noises due to the OBX "sleeved" coilover system on stock shocks="HARSH RIDE"
-If your planning on dropping your car 2-2.5 inches all-around it's a good idea to upgrade your shocks if not you'll result in a "HARSH" ride.
All in all,I suggest you sell the OBX "sleeved" coilovers and get either a basic shock/spring set-up or "TRUE" coilover set-up. But hey,It's your car,do what you want to do.
Old Jul 22, 2003 | 08:26 PM
theMax's Avatar
what exactly is the problem with these coilovers? Coilovers have a harsh ride by design, is it because of the 'sleeved' design? more info please.
Old Jul 22, 2003 | 08:35 PM
asu174's Avatar
Clay Aiken has fancy genitals
Why? Because OBX Coilovers are pieces of crap. You got them cheap for a reason.....because they suck.
Noise will come mainly between the spring and the lower perch. You will probably also get some from your stock struts bottoming out, as well as at the upper spring perch.
Old Jul 22, 2003 | 10:23 PM
MaxTuner's Avatar
Listen to the advices man, they are for your benefits!
smplyamzng
Dec 13, 2015 01:19 PM
homeyclaus
Sep 3, 2015 06:15 PM
lowpost99
22
Sep 2, 2015 04:38 PM
TonyJr
Aug 20, 2015 12:14 AM
laparka66
Aug 6, 2015 09:36 AM
