steering wheel shakes when braking
Old May 10, 2003 | 07:30 AM
Galo's Avatar
Maxima Pilot
warped rotors...
If under 30k miles, take to dealer, TSB for this problem, very common in Gen5 Maxes, particularly 2000 and 2001's.
Old May 10, 2003 | 07:33 AM
NT2SHBBY
Originally posted by Galo
warped rotors...
yup and very common amongst 02-03's......especially if left sitting at dealer lots
Old May 10, 2003 | 09:07 AM
Wasim521's Avatar
Can anyone post the TSB? I can't find it here, the link in the TSB section doesn't work.
Old May 10, 2003 | 09:20 AM
Maxman2000's Avatar
warped rotors...
Yup, a very common problem in 5th gens
Old May 10, 2003 | 10:02 AM
MacGyver's Avatar
i had to get mine resurfaced after 3k miles and now at 13k it's starting to shake again....are they suppose to replace them after multiple problems or just keep resurfacing until it's out of warranty?
Old May 10, 2003 | 10:14 AM
augie's Avatar
I had that same problem with my '00 max and now with my '02 max. I guess aftermarket rotors would be the remedy? Some x-drilled ot slotted?
Old May 10, 2003 | 10:19 AM
nissan5788's Avatar
So it is covered under the normal warranty?
Old May 10, 2003 | 10:52 AM
foodmanry's Avatar
Da Roller Coaster!
Covered up to 36K miles, and usually you only get your rotors resurfaced. After that MOST dealerships will say no. There are the few and far between dealerships that will resurface after 36K.
The best solution is to put aftermarket rotors on. The stock ones will warp again even after they are resurfaced.
Old May 11, 2003 | 09:13 PM
billyman's Avatar
Here's the TSB for the Brake Judder.
https://maxima.org/maxfaqs/images/5g/tsb/brake/1.jpg
https://maxima.org/maxfaqs/images/5g/tsb/brake/2.jpg
https://maxima.org/maxfaqs/images/5g/tsb/brake/3.jpg
https://maxima.org/maxfaqs/images/5g/tsb/brake/4.jpg
https://maxima.org/maxfaqs/images/5g/tsb/brake/5.jpg
Good luck w/the resolution.
Old May 11, 2003 | 10:52 PM
LatinMax's Avatar
Just do the 300zx brake mod. That's what took care of that problem on my car. I have a write up on it on page 2 of my site.
http://maxima.cardomain.com/member_p...=286919&page=2
lowpost99
Oct 26, 2025 06:53 PM
BkGreen97
Apr 2, 2016 05:47 AM
dcam0326
Sep 8, 2015 11:02 PM
coasterswim
Sep 2, 2015 07:43 AM
