14.9 need help
Old May 12, 2003 | 09:42 PM
bassfreak's Avatar
14.9 need help
so i went to the track last friday and i ran a 14.9 with a 2.26 60' and a 94.xx trap. oh and my car is a 2000 5m. i have jwt intake custom cat-back to apexi n1 muffler ans warpspeed y-pipe. also 17" centerline rpm's only 13lbs each. i was hoping to be faster are these normal times what mods should i buy. thanks in advance.
Old May 12, 2003 | 10:26 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
nitrous, blowers.
Old May 13, 2003 | 05:05 AM
mattattax's Avatar
do you have any pics of your car with those rims?
sorry I can't help with mods, I'm not sure what those 2k-2k1 guys recommend
Old May 13, 2003 | 03:18 PM
92 SE-R 02 SE
Originally posted by killer2002SE
nitrous, blowers.
you have times for your car? Did you have to change the fuel pump and/or injectors?
Old May 13, 2003 | 06:53 PM
PCGuRu2K's Avatar
It appears it's about time you got Blown
Old May 13, 2003 | 08:09 PM
bassfreak's Avatar
i was actually going to buy the nx kit but my tranny is starting to grind in second so i want to get that taken care of first. i figured my car would be faster but oh well. and i probably could get pics of the wheels up. my car is black and so are the wheels. and it looks amazimg.
Old May 13, 2003 | 11:25 PM
95emeraldgxe's Avatar
remove all the crap in your trunk and take the back seat out
Old May 14, 2003 | 05:42 AM
wantasupra3's Avatar
Make the car lighter...take out the spare tire, tools, back seat, crap in the glove box, and a 1/5 of a tank of gas!
Old May 14, 2003 | 06:01 AM
2K2_6spd's Avatar
Get a 2k3, that will get you in the low 14's
Old May 14, 2003 | 06:03 AM
Blu's Avatar
Blu
the tits
first off whats the elevation of your track....
Old May 14, 2003 | 08:52 PM
bassfreak's Avatar
920ft. never thought of that. good call how much does this affect my time
Old May 14, 2003 | 10:27 PM
Eat Naaawwwzzzzz
didnt touch the fuel system..totally stock..
Times, ive only ran once with a MESSED up start..i zoned off..1.4 r/t and didnt squeeze until late 2nd gear.. i got a 14.2
I wasnt happy
Old May 15, 2003 | 04:02 AM
Blu's Avatar
Blu
the tits
that could cost you a 1-2 tenths and .5-1 mph in your traps from a track at sea level. Aaron has ran a 14.8 @ 92 here in NC at a 100ft and 15.1 @ 91 at 1150ft so thats just a little example.
Old May 15, 2003 | 06:03 AM
Chinkzilla's Avatar
that's a great time for a VQ30 5th gen.. Most people are in the low 15's
Some better traction, less weight, and less elevation should get u into the mid 14's
Old May 15, 2003 | 09:09 AM
bassfreak's Avatar
udp just got in. installing at work later tonight. then a week from friday i will be back at the track. hopefully with better times.
Old May 15, 2003 | 09:13 AM
bassfreak's Avatar
14.761 @ 93.09 - 2.22 60' - 2000 SE manual quote:
2000 SE 5 Speed
Mods: Stillen Intake, Stillen Y-pipe, Pacesetter STS
i just dont understand because all of my traps were 94-95 and my 60' was 2.25-2.3
Old May 15, 2003 | 11:31 AM
Chinkzilla's Avatar
different track, different conditions, different day, different wind, different tires, different track weight, could be a million things.
Old May 16, 2003 | 10:38 PM
bassfreak's Avatar
thanks for the imput but i still dont understand how my trap would be 3mph higher with a worse time thanks. but is there anything else i can do.
Old May 17, 2003 | 08:46 AM
Chinkzilla's Avatar
lower your tire pressures, your 60's are not as good as they can be, if you drop your 60' by a tenth you should see maybe two tenths drop off your quarter. Also take some weight out of your car. Spare tire, trunk lining, rear bench. How much gas did you have? try to run with less than 1/4 tank. If you have adjustable shocks, put the rears on full stiffness.
Jasonb1982
1/4 and 1/8 Mile Racing
Jul 24, 2004 05:39 PM
xfirepwr1
34
Sep 3, 2003 01:20 PM
SR20DEN
Apr 1, 2003 05:41 PM
Dave B
Feb 4, 2003 11:10 AM
Nealoc187
Jan 13, 2003 02:40 PM
