How does a Powered Sub work?
Old May 13, 2003 | 02:01 PM
golzbra's Avatar
I think I remember one of you guys hooking up a powered sub to the factory Bose system.
1. How does a powered sub work?
2. And how do you install it??
3. Also, what are the advantages and disadvantages???
Thanks.
Old May 13, 2003 | 02:06 PM
jjs's Avatar
jjs
Re: How does a Powered Sub work?
Thanks.
If you don't get full answers here, this is the exact type of question the AUDIO forum is good for....
Old May 13, 2003 | 02:13 PM
golzbra's Avatar
Audio forum??....we have too many forums....lol...thanks. Still hoping someone here can answer my questions....I can't keep track of all these forums and where I have questions posted.....that's right, I have to go check the southeast forum.....god almighty.....I think we should create a wheels forum....oh....we have one...my bad.
Old May 13, 2003 | 02:15 PM
jjs's Avatar
jjs
Old May 13, 2003 | 02:31 PM
TimW's Avatar
The silent but deadly Moderator
if you drop a post in a forum you dont check often, then simply 'subscribe' to that thread.. you will be emailed when/if there are replies.
Old May 13, 2003 | 04:04 PM
jmh8's Avatar
Get the infinity basslink. Sounds great. Look on e-bay. Dirt cheap right now and $60 to install. Sounds great with the bose system. I took out the Bose sub and used the hole as a port.
Old May 13, 2003 | 05:11 PM
maximamaybe's Avatar
It works by having an amp mounted in the box. Basically the infinity basslink is an amp and sub mounted in the same box. You run power and signal to it and you are set.
Advantage is that it is small and in one container.
Disadvantage is that it will never be as loud as a dedicated amp/sub combo with a well designed box.
maxinout93
Oct 27, 2015 01:29 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
