Link to install clear fronts
Old May 14, 2003 | 08:05 AM
95maxmadman's Avatar
The one on the FAQ is broken.
Can anyone hook me up?
Old May 14, 2003 | 08:16 AM
BiggD23
Do you mean clear corners?
Old May 14, 2003 | 08:19 AM
The ugly orange blinkers.
Are they called corners on the 5th gen?
I'm a 4th gen guy, trying to hook my brother up.
Old May 14, 2003 | 08:26 AM
BiggD23
Yeah, the ugly orange corners on the front left and right of the car. And the matching ugly red ones in the rear. That what you mean? If so I made a Word document with pics out of the How-to when it was still working, I can email it to you if you want. Installation is a snap, it should take 10 minutes tops. The hardest and most time consuming part is sealing the clears with some clear silicone before installing them so they don't get condensation in them.
Old May 14, 2003 | 08:39 AM
definitely.
jason.gerardi@fmr.com
thanks.
Old May 14, 2003 | 09:25 AM
BiggD23
No problem, I just sent it.
Old May 14, 2003 | 09:47 AM
eclane's Avatar
Also look in the owners manual. It tells you how to remove the markers
Old May 14, 2003 | 09:54 AM
hockeyboy82's Avatar
sup guys...i don't have any silicone on my clears...where exactly on the clears should i put some cuz it seemed to me that the only place condensation could get in is where the bulb goes into the lense?
Old May 14, 2003 | 10:15 AM
BiggD23
You need to reseal where the clear lens meets the back plastic piece. On mine the clear lens kind of overlapped the plastic piece, so I just made sure to seal where the lip of the clear piece meets the grey back plastic piece real good with silicone and let it dry overnight. It looks kinda ugly from the back once it's done but no one will ever see that side anyway. The factory seals on these things seem to be cheaply done. You might not get condensation right away, or even at all if you happened to get a good set. It's just an inexpensive way of avoiding a headache down the road.
Old May 14, 2003 | 10:22 AM
ok thanks a lot im gunna check em out later and see wat the seal is like.
homeyclaus
Sep 3, 2015 06:15 PM
DZN13
Aug 24, 2015 11:00 AM
doobadoo
Aug 15, 2015 06:43 PM
mikekay
Aug 10, 2015 12:52 PM
laparka66
Aug 6, 2015 09:36 AM
