what is double clutching
SO what is double clutching really? anybody actually does this when they are at the track? cuz on fast and the furious, if u remember, the guy said the cop wasnt double clutching like he should. So sounds like double clutching is something u should do? someone tell me more about this please. thanks
Re: what is double clutching
[QUOTE]Originally posted by PimpShiFu
SO what is double clutching really? anybody actually does this when they are at the track? cuz on fast and the furious, if u remember, the guy said the cop wasnt double clutching like he should. So sounds like double clutching is something u should do? someone tell me more about this please. thanks [/QUOTE
It is something you do on 10 second hondas and 18 wheel trucks. Some dump trucks/garbage trucks too.
yep, some big trucks have lots of gears. After you pass 1-5 you double clutch to get to 6-10. Its to avoid having a 10 position gearshift. As for the FnF??? just some BS that sounds cool I guess unless they have some super tranny.
I thought it was releasing the clutch while in nuetral (between shifts) and stepping on the gas to get the intermediate shaft up to the speed you want it at (so that it meshes better with the gears)...apparently this is what syncros do in transmissions - I may be wrong though.
double-clutching is what the muscle car racers had to do(some still do) because they didnt have the synchro trannys that we have now. Double clutching is simply a method to get it out of a gear(clutch #1) and put it back into a gear(clutch #2). When going into a less powerful gear, this gives the driver a moment to rev the engine to a more suitable RPM.
JRS
JRS
Originally posted by DOM
Look at these videos. it explains double clutching
http://playground.sun.com/greg/
Whenever I drive an old "deuce and a half" - 2.5 ton Army truck - I have to double-clutch to downshift going up hills. It helps avoid grinding the gears.
All it basically is... is pressing the clutch in once to disengage as you start to shift, and while shifting, releasing and pressing the clutch in again to synch the tranny.
-R
-R
If you double clutch with synchronized gears you're wasting time. If the gears are straight cut (non synchro) then you either double clutch or powershift. If you try to power shift synchronized gears you'll trash the synchros, either on the upshifts or the downshifts (it will shift smoothly in one direction, but not the other). There's nothing like powershifting a good race gearbox or bike.
Bottom line, just shift "normally" your max.
worldwiderecognized
Sep 30, 2015 01:16 PM
carlosvq30
Sep 26, 2015 09:44 AM
