how to aim HIDS higher?
Old May 20, 2003 | 10:50 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Hey, Ive just realized barely after like 5 months that after I lowered my car, the beam is a lot lower and I heard that there is a way to aim the HIDS a bit higher
Anyone know how?>
Can you post me a picture of the alinment thing?
Old May 20, 2003 | 10:52 PM
iLLin-2k1's Avatar
http://www.autooptiks.com/aiming.html
Located in the How to's... Thanx to BigDogJonx
Old May 20, 2003 | 10:58 PM
Eat Naaawwwzzzzz
thanks for that, But im actually referring to the actual aiming device on the headlight housing
Old May 20, 2003 | 11:02 PM
iLLin-2k1's Avatar
My appologies, im new
Old May 20, 2003 | 11:05 PM
NizanDrivn's Avatar
newbies go figure...
on the back of the headlight there is a white gear that you need to turn...I forget exactly which direction makes the beam go up/down...
It's a little difficult to turn though, you need the right tools...
have fun...
Old May 20, 2003 | 11:07 PM
Eat Naaawwwzzzzz
thanks for your help guys,
and iLLin-2k1, welcome to the org..
BTW, thats a nice ride
what suspension are you running?
iLLin-2k1's Avatar
ground control coilovers
Old May 21, 2003 | 01:53 AM
AYAYAY's Avatar
have fun...
I just happened to adjust the headlights this past weekend. The only tools you'll need is a very small flathead screwdriver and a flashlight. As NizanDrivn said, you'll need to turn the white gear behind each housing. There's a slot on the side made for you to stick the screwdriver. If your facing forward (the same direction as the car is pointing), turning the gear counter-clockwise will raise beam and clockwise to lower.
Good luck!
Old May 21, 2003 | 02:42 AM
Triple8Sol's Avatar
I miss the .org!
No matter which way you face the gear, counterclockwise is the same...liekwise for clockwise turning
Thanks for the link illin, I was just thinking I need to do this adjustment!
Old May 21, 2003 | 06:47 AM
Eat Naaawwwzzzzz
I can actually see the road now
I didnt know how high to go, mso I did a lot ot turns and my lights were pointed at some palm trees! lol
The tool that should be used is a 8MM ratchet.
While a screwdriver may work as well, you can strip it or not be as accurate...
THanks for all the help guys
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
uttadms31
Sep 30, 2015 05:24 AM
Vistance
Sep 17, 2015 05:17 AM
