wheel spacers
Old May 21, 2003 | 01:52 PM
joeyd's Avatar
wheel spacers
anyone have them on their max?..if you do what size?..i dont know much about them, but i want the rear wheels to line up with the fender like the fronts do...5mm, 15mm, 20mm?????
Old May 21, 2003 | 04:35 PM
CJLax's Avatar
H&R's wheel spacers
Got mine from Optionauto. 5mm for the front and 20mm for the rear. If you have the same offset as the oem rims this size will do the trick. I also have H&R springs on my 2k2. $55 for the 5mm and $100 for the 20mm. Well worth the money. No vibration and also hubcentric. Make sure when you order that the lugs are the same bolt size. The 20mm came with 1.5 lugs. The fronts came with 1.25, so I have two different lug sizes. With this size you only have to replace the rear lugs to accomodate the 20mm spacer. My wheels fill out the wheel well and the car looks impressive. I get a lot of compliments. Also I have 18x8 rims with same factory offset as oem rims. Forgot the size off hand.
Old May 21, 2003 | 05:07 PM
soundmike's Avatar
Very sound, Mike
Lemme get this straight, one would need 5mm for the front, 20mm for the back and what else?
Where'd you buy it btw?
Old May 21, 2003 | 05:31 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Hey Mike, how 'bout you gettin a GD going on these???
Looks like it would be a desirable mod!!
Old May 21, 2003 | 07:16 PM
soundmike's Avatar
Very sound, Mike
I'll see what i can do, still gotta learn about the mod first
Old May 21, 2003 | 07:23 PM
Bluesbrekr's Avatar
Cool! According to this thread, longer studs are obviously needed for the 20MM rear spacer. Seems like the rear spacers are currently backordered from a couple vendors. Anyway, I'd most likely be interested if you can get somethin' going!!
Old May 21, 2003 | 07:29 PM
spta97's Avatar
Old May 27, 2003 | 03:36 PM
joeyd's Avatar
anyone have any pics with the spacers on there car...w/stock wheels or not?
Old May 27, 2003 | 03:42 PM
Galo's Avatar
Maxima Pilot
I am checking weekly with H&R -whose US offices are in close by Washington State- and both the 15 and 20 mm spacers are back ordered and wre expected to continue thus for another two to three weeks...I too have 15mm on order and waiting and waiting and waiting....
Old May 28, 2003 | 04:54 AM
RichK's Avatar
I have the 20mm spacers and yes I will try and post pics later this week. As far as lug sizes go, CJLax, you got the wrong studs. I also got the 1.5 studs with my 20mm spacers. I called H&R and they said that they are wrong. I then called ECStuning(where I got the spacers from) and told them about it. They contacted H&R and I recieved the correct studs. My guess is that when the 20mm spacers were packaged, they put the wrong studs in. The crappy part is that I had already installed the studs when I found out the lugs were different. What a PITA.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
