WRITEUP!! Dash Clock Re-wire
Old May 22, 2003 | 08:13 AM
Rob'sAE's Avatar
You're Faster, I'm Better
Ok guys, my first write up. I had seen this somewhere before but was unable to find it anywhere when I was ready to do it. So what I did was go out and figured it out myself. This needs to be put in the STICKY please.
If you do the fog light re-wire chances are you use them as your daytime running lamps too. The problem is when your lights are on the clock dims and becomes impossible to read during the day. The fix, make it so it does not dim. Pop out the clock, doing it in such a way as to not scratch the dash or the clock. It will take a nice little bit of force but as long as it is removed straight up nothing should break. Then look for the red wire with blue stripe(2001) and disable it however it suites your fancy. I removed it from the actual wiring harness and taped it up so that I can restore it's function later by plugging it back in. Put everything back and re-set your clock and your all done.
I am not responsible if you are a nincompoop and screw up your car. ENJOY
Old May 22, 2003 | 08:18 AM
Maxman2000's Avatar
Mmmmm. Getting Ideas.
Old May 22, 2003 | 08:20 AM
Maxman2000's Avatar
Now that you sed that. I'd like to do the door LED swap out and have the LED's on when the key is in the on position. And maybe have them as blinkers to. letf turn blinker blinking, left door controls blinking.
Old May 22, 2003 | 08:45 AM
tecman4's Avatar
Daytime running lights suck
Old May 22, 2003 | 09:28 AM
Maxman2000's Avatar
They don't really bother me. I'm used to it If there on during the day time, they make your light seem shinyer (I think.)
Old May 22, 2003 | 10:46 AM
optimus1's Avatar
amen!
what a pain ... as the sun goes down and it just starts to darken a little, a truck with DRL is coming at you ... blinded !!
They should not have used the hi-beams and the running lites !!
Old May 22, 2003 | 10:49 AM
jjs's Avatar
jjs
Like many things in life, I think the novelty has died off so much that what used to grab your attention is now just background noise in the driving adventure. I know I don't really even pay attention to them anymore.
Old May 22, 2003 | 10:52 AM
2K255HP's Avatar
In Canada by-law, cars here have to have dtr lights, i think it applied to all cars built after 1989? something like that lolz...
on a second note:
Has anyone in Canada done this fog-rewire, and since we already have dtr lights w/o having to swtich them on, what wire was tapped into instead of the clearance? or is it even possible to tap into the high beam bulb?
Old May 22, 2003 | 10:54 AM
2K255HP's Avatar
In Canada by-law, cars here have to have dtr lights.
on a second note:
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
