Front Window Auto Down with Remote?
Old May 27, 2003 | 07:14 AM
jreddington
The owner's manual on my '03 SE says to hold down the unlock button on my remote for 3 seconds to lower the front driver and passenger windows. When I do this they lower about 2" and then stop. If I press unlock again for 3 seconds they will go down the rest of the way.
Is this the way it is supposed to work? From the wording in the manual it sounds like they are supposed to go down completely. I don't think it's a reception problem because I've tried it standing only a couple feet from the car.
Old May 27, 2003 | 07:15 AM
NT2SHBBY
just hold down the remote without letting go...they'll go down fully
Old May 27, 2003 | 07:30 AM
Zog's Avatar
Zog
I have the same problem. Try hitting unlock once and then twice (like you were unlocking all the doors) and holding the second press down the. *Sometimes* that works for me.
Old May 27, 2003 | 08:48 AM
Maximax2's Avatar
Re: Front Window Auto Down with Remote?
>>>>>>>>>>EDIT: Forget what I said - read sorcereur's post below, he's right.<<<<<<<<<<<<
Old May 27, 2003 | 08:55 AM
sorcereur's Avatar
Actually, this is entirely normal. It was discussed before and they all do this. If you let it stay for an hour or longer, that's what happens. The windows only go down about those 2", then u can press it again and have it go down all the way. If you shutdown the car and do it within the hour, they go down fully. It's not an interference in the signal because it does the same thing even if you are right there in front of the car. Give it an hour or so, come stand right by the hood and it'll only drop the windws 2".
Hope that helps.
Old May 27, 2003 | 09:12 AM
Maximax2's Avatar
Originally posted by sorcereur
Actually, this is entirely normal. It was discussed before and they all do this. If you let it stay for an hour or longer, that's what happens. The windows only go down about those 2&quot;, then u can press it again and have it go down all the way. If you shutdown the car and do it within the hour, they go down fully. It's not an interference in the signal because it does the same thing even if you are right there in front of the car. Give it an hour or so, come stand right by the hood and it'll only drop the windws 2&quot;.
Hope that helps.
Wow, that's interesting. I'm about to go to lunch, I'll test
>>>>>>>>>>EDIT:
You sir are the winner! That's EXACTLY what it does. After leaving my car in the parking garage for a few hours, the windows only went down 2" on first button hold. After only five minutes though, they went down all the way on first hold. And thanks, this is a mildly obnoxious habit of my car that I now understand. <<<<<<<<<<
Old May 27, 2003 | 09:18 AM
kklier's Avatar
The owner's manual on my '03 SE says to hold down the unlock button on my remote for 3 seconds to lower the front driver and passenger windows. When I do this they lower about 2&quot; and then stop. If I press unlock again for 3 seconds they will go down the rest of the way.
So this is what seems to work on my 2k3 SE.
Click the remote once and hold it, windows go down a couple of inches. Click the remote twice(like you are unlocking all doors) and hold it, windows go down all the way.
Old May 27, 2003 | 10:04 AM
jreddington
Yeah, I've tried the "press twice and hold" method and got the "sometimes" working response. Maybe my "sometimes" is related to this sit for an hour thing. I'll have to try the various permutations of under and over and hour plus one and two button presses. As someone else mentioned I don't think it is a reception problem since it does it even when I'm standing beside the car and the windows always go down the exact same amount. If it was a reception problem I would assume the down distance would be random.
Anyone here ever heard of any reason why an hour would make a difference or is it some inscrutable Zen Japanese logic that the Occidental (Or Celtic in my case) mind is unable to fathom?
Old May 27, 2003 | 01:01 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
Just UNLOCK the car before you remote the windows down then they willl go all the way down
The car doesnt want to open the windows with the doors locked thats all.
TRy it and let me know
Old May 27, 2003 | 01:19 PM
raiste's Avatar
I just wish I could make them go UP remotely. Making them go down is nice, but Nissan should have given the option to sliding them back up as well.
Old May 27, 2003 | 06:09 PM
MadMax1996's Avatar
My aunt picked up a G35 sedan and she's had it for about a year. She's so paranoid about driving it so it has less than 5000 miles on it! I stopped by to show her my new Maxima and showed her the remote window feature. She thought it was awesome. I told her to get the keys and sure enough she even has the same remote.
I held down the button and not only did hers go down all the way - it lowers all four windows on the G35!
I wish you could hold down the lock button and they would go up. Can't complain tho - it's nice to air the car out when it's been sitting in the sun.
Old May 27, 2003 | 06:29 PM
slickrick's Avatar
that would be sweet. my windows do the same thing, sometimes they go down all the way the 1st time, sometimes they dont.
Old May 27, 2003 | 07:07 PM
Darius's Avatar
why cant my '01 do this?
Old May 28, 2003 | 07:36 AM
jreddington
Seems like the sitting for the hour thing is the key. I've experimented since my first post and it does look like after a while (I haven't pinned it down to exactly an hour but seems about that) when you press and hold the remote it only goes down 2". A 2nd 3 second unlock hold is required to drop them the rest of the way. In response to one post, unlocking (one push) followed by press and hold does not drop them all the way after the hour waiting period.
I read in another thread about auto headlight sensitivity settings that there are computer settings that the dealer can change for things like the headlights and these locks. Noted that they can even be changed to lower all four windows. Has anyone heard of this? What else can you adjust? (Auto door locking - lock driver or passenger and all lock, like my '92 would ge great). Is there anything on this in the official service manual. I'm still trying to pick up one of these manuals on CD from ebay but keep getting overbid at the last minute.
Some of the other reported behavior on this thread may be related to changed computer settings.
Old May 28, 2003 | 07:38 AM
NT2SHBBY
u can make the windows go up with the key...turn the key the opposite way (I think it's left) the windows go up
Old May 28, 2003 | 09:08 AM
MaximaMan77's Avatar
True, but that sucks when it's raining.
Old May 28, 2003 | 02:11 PM
Maximax2's Avatar
If it's raining, why would you roll the windows down?
Old May 28, 2003 | 02:27 PM
lol
We were talking about getting them to go up.
Old Jun 1, 2003 | 12:53 PM
Darius's Avatar
could i take my 2k1 GLE to the dealer and have them enable the remote down/up front (and rear?) windows?
Old Jun 1, 2003 | 01:57 PM
92 SE-R 02 SE
i think you are correct. Like someone else said, i wish we could use the remote to make them go up! Stupid nissan!
Old Jun 1, 2003 | 08:39 PM
jreddington
Probably not stupid Nissan but probably the same PITA lawyers that make you press the enter button every time the nav system fires up.
Even though the windows have a safety feature to make sure they don't crush fingers when you use the auto up feature, the lawyers were probably worried about the remote possibilty that you would auto up the windows with the remote without you being in line of site of the car while someone was holding a baby's head in the window, the saftey feature failing, and the windows crushing the little rugrat's head (or anybody else's body part).
Old Jun 1, 2003 | 08:44 PM
slickrick's Avatar
or they can make that a "new" feature for a 2k5 or something to keep it fresh. i believe the 2k's don'thave it, but the 2k2's do.
Old Jun 1, 2003 | 09:23 PM
E55AMG2's Avatar
Wat
Change the battery in your remote and it will work better.
Old Jun 2, 2003 | 12:13 PM
gtbigup's Avatar
You can just install a viper 650XV and they will go up as you arm it and come down as previously discussed.Cost $445.00
Old Jun 2, 2003 | 05:25 PM
slickrick's Avatar
i tried that and it didnt work.
Old Jun 2, 2003 | 07:12 PM
Maximax2's Avatar
Huh - worked for me when I tried it. Unfortunately, it's still only the front windows (it would be sweet if all windows and the sunroof automatically closed )
Old Jun 2, 2003 | 07:30 PM
slickrick's Avatar
how do i move my key back? ive tried it before and it wont work. maybe im not doing something right. in my old car it did it fine i could turn on the radio without the a/c but in ym max i have to turn the key partially on to get power which uses the a/c. i cant get it to go backwards and do just power without a/c.
Old Jun 2, 2003 | 07:39 PM
Maximax2's Avatar
It's in the driver's door, not the ignition. With the windows down, put the key in the door, turn to the left and hold - windows go up.
Old Jun 2, 2003 | 07:42 PM
slickrick's Avatar
ohh. ive known that trick. but its not really a trick because it takes more time to put the key in than to just click window up on the door. my friends hyundai has a feature that even if the key is out he can roll his windows up with the door buttons. now why doesnt my maxima have this?
Old Jun 3, 2003 | 06:08 PM
jreddington
The Maxima does this (at least my '03). When you remove the key from the ignition power remains to the windows and sunroof for up to 45 seconds or until you open the door.
Using the key in the door to raise the windows is easier (if you've forgotton to close the windows or later want to raise them) than opening the door, putting the key in the ignition, turning, then using the door buttons to raise the windows.
Still, I'd love to be able to do it with the remote as I'm walking away.
Old Jun 3, 2003 | 09:42 PM
slickrick's Avatar
true. ill have to check that feature out. whenever i try it the door is already open, ill try it with the dor closed tomorrow and see if it does work.
Old Jun 3, 2003 | 10:02 PM
Jimmimax's Avatar
Its just silly. My 98 Would just go down until I decided to let go. 1-2 inches ( timing is everything ) or all the way down, first try. Sitting, not sitting. Locked , unlocked. OK, guess I'll just have to get used to it. What is harder to get used to is the fact that the Sunroof doesn't always go back first try. I have to " wait " and try again Rrrrr.....
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
KGMtech
Aug 18, 2015 09:21 AM
kjm900r
Aug 5, 2015 07:14 AM
