Just rewired fog lights...much better
Old May 27, 2003 | 04:34 PM
JoeyC502's Avatar
I didnt like how the only way you could turn on the fogs was with your headlights. I Rewired them so I could turn them on with the parking lights. I like the look much better.
Old May 27, 2003 | 04:39 PM
Teser's Avatar
Re: Just rewired fog lights...much better
did you use one of the writeups on the ORG, or just did it yourself?
Old May 27, 2003 | 07:10 PM
JoeyC502's Avatar
I did it myself. Real easy. Took me about 30 minutes.
Old May 27, 2003 | 07:21 PM
WildmanAL's Avatar
Do you have a 00,01 or 02,03 max. I think there was some confusion with the 02,03 maxima on how it was done. Can you do a quick writeup on this because I want to do this mod myself.
Old May 27, 2003 | 09:32 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
I can for you, took me less then 5 minutes.
Open the fuse box, Look on the cover for the fog light relay and look under for a blue wire with horizontal silver marks every 5 inches or so.
Then Look for the Cornering Lamp in the cover and grab the Red wire with the vertical green stripe.
Cut the blue wire and tape up the end going down. Use a tap, and tap the blue wire from the relay to the ren wire with the green stripe.
Took me about 5 minutes, 4 of the minutes were opening the fuse box....
This is by far the easiest way ont he 2k2
Old May 27, 2003 | 09:40 PM
WildmanAL's Avatar
Perfect, thanks a lot. I'll be doing this tomorrow.
Old May 28, 2003 | 05:13 AM
NT2SHBBY
this is a total fukin newb question, but what is a "tap"???
I'm not electrically inclined, mind you
Old May 28, 2003 | 05:30 AM
spta97's Avatar
Does anyone know...
...how to wire the fog lights so they stay on with the high beams?
Old May 28, 2003 | 05:37 AM
NT2SHBBY
Re: Does anyone know...
I think with that mod, they work anytime, highs/no highs/no lights at all
Old May 28, 2003 | 05:57 AM
t56gen3's Avatar
If you follow the instructions I posted you don't have to run any wires outside the relay box, and no extending anything.
The way you are wiring this puts an extra load on the all the front end wiring. My method grabs current right off the parking light relay and does not pull it through all the wire leading up to the parking light. You want to splice the blue/with silver dots on the fog light relay into the red/green off the parking light relay. I can supply a pic if you need.
Either way will work, but mine doesn't involve adding any wire and would be easier.
Old May 28, 2003 | 06:00 AM
NT2SHBBY
OT, but check ur PM's dude..I need ur help...if you can go on AIM, it would be greatly appreciated
Old May 28, 2003 | 04:10 PM
JoeyC502's Avatar
But its ok the way I did it correct? I wont be blowing any fuses will I? thanks
Old May 28, 2003 | 04:26 PM
t56gen3's Avatar
Unless you start blowing fuses, I wouldn't worry about it. You should be ok.
Old May 28, 2003 | 04:40 PM
PoLo's Avatar
2-Wheelin it...
1) a tap is a cute little thingy that when put over a wire, cuts into it without cutting the wire. the real name is a "t-tap" because it wraps around a wire perpendicularly. you can then plug antoher wire into it. it's one of the easiest ways to "tap" into wires without completely cutting them from each other. it's also very clean.
2) this mod will always turn off the fogs when high beams are on. this is, i believe, a protective measure so as to not to send to much power through the wires. if you were able to drive with highs, fogs, clearance, and side markers, something may burn up.
now, if you really want to make it so you can high beam and keep the fogs on, i'm sure there is a wire that you have to reroute. i'll snoop around the fsm and see what i find.
Old May 28, 2003 | 05:00 PM
jesse's Avatar
VTEC This!
same for '00 or nah? i think i may actually be able to do it, if i had an easy tutorial like this one to help out...
Old May 28, 2003 | 05:45 PM
PCGuRu2K's Avatar
Did someone ask for a tutorial?
http://www.max-world.org/writeups/5t...fogrewire.html
Old May 28, 2003 | 07:00 PM
woosh's Avatar
I'm not sure if running the fogs concurrently with the high beamm would push any of the circuits beyond the fuse limit , thereby blowing a fuse.
The real reason the fogs do not work with the high beams on is because the high beam switch is in series with the fog switch's path to ground. To get them to work together you would just have to take each switch out of each others path and wire them in parallel.
I gave instructions in another post but cannot search it back for you. It was in the post with t56gen3's howto.It is easier to wire if you trace the wires from the top of the steering column or if you know of some other point you can locate the wires. The switch for the fog is right there when you take off the cover around the steering, on top.
The wiring for 2k,2k1's are different from 2k2,2k3 mostly because the wire colors are different, but the fog working with the high beam concept is the same
SHIFT_woosh
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
