What are correct A/Fs for the Max?
Old May 28, 2003 | 01:12 AM
Regime's Avatar
The non-postwhoring Org member
When I was dyno'd at ATP last week, My A/F's were at a pretty steady 15. I thought they were suppose to be closer to 12. Anybody have an idea to what may be causing this? All my mods are listed in my sig.
Anyone???
Old May 28, 2003 | 04:07 AM
Blu's Avatar
Blu
the tits
12.5-13 is optimal you seem to be running a bit lean
Old May 28, 2003 | 06:59 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: What are correct A/Fs for the Max?
Anyone???
what kind of numbers did you put down?
Old May 28, 2003 | 07:09 AM
Blu's Avatar
Blu
the tits
Re: Re: What are correct A/Fs for the Max?
quick askin everyone and dyno your weak sauce...maybe it will see track time one of these centuries
Old May 28, 2003 | 09:02 AM
Regime's Avatar
Thanks...but....Yeah I am assuming that I am lean because of the A/F's being so high, I am really looking for a teason that they are so high. I really don't think that my mods would even come close to taxing the fuel system, so my question remains...What could be causing this?
185.1HP/182.4lb. But my throughout my curves I have gained 5-10hp and 4-9lb over my stock numbers.
Old May 28, 2003 | 09:50 AM
Blu's Avatar
Blu
the tits
about the only fix would be to get a SAFC and tune it by adding and subtracting fuel to richin or lean it out
Old May 28, 2003 | 10:01 AM
Regime's Avatar
But there still must be something causing this to occur, like weak fuel pump, malfunctioning injectors, ECU error...something...I mean the car's stock system should be able to compenstate for the few extra hp that I have added. I mean there are people running 50shots without any fuel management and are doing just fine..
Old May 28, 2003 | 10:06 AM
Blu's Avatar
Blu
the tits
I dont know what to tell you...my buddies 02 6spd was bottoming 10 a/f and all he has is intake, exhaust,udp...no y pipe or anything.
Old May 28, 2003 | 10:43 AM
irvine78's Avatar
you could get an adjustable fuel pressure regulator and control your air/fuel mixture a bit..
Old May 28, 2003 | 11:55 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Seems lean to me, your mods are going to cause it to lean a wee bit, but not that much. Weak fuel pump or clogged filter maybe? A/F monitor wacked?.
12:1 is good for FI cars, N/A's should be 13-14:1 at WOT.
Old May 28, 2003 | 12:14 PM
UMD_MaxSE's Avatar
Got Bent?
15 is kinda high... I have the same mods as you and same car essentially and my A/F was high 13's - 14 when I dyno'd... put down numbers similar to yours. Maybe get a fuel pressure gauge on there to see what kind of pressure you are getting... maybe try some fuel injector cleaner
Old May 28, 2003 | 02:00 PM
BigDogJonx's Avatar
Nauman,
I didnt know you dynoed those numbers. Damn I was a bit higher than you with the same mods as well as 19" wheels. Im starting not to believe this heavy wheels weight myth.
Dixit
Old May 28, 2003 | 02:07 PM
UMD_MaxSE's Avatar
Got Bent?
yup.... I dyno'd with my 18's...
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
leatherneck
Sep 30, 2015 09:16 PM
maxima297
Sep 30, 2015 03:32 PM
