Tire wear
Old May 28, 2003 | 07:06 AM
rbourne's Avatar
Tire wear
Can anyone explain in why the rear tires of my '02 Max SE are wearing out before the fronts?
Thanks,
Bob
Old May 28, 2003 | 07:09 AM
NT2SHBBY
u got the special RWD model we were all looking for...
seriously tho, that sounds wierd...
Old May 28, 2003 | 07:10 AM
jjs's Avatar
jjs
Re: Tire wear
Thanks,
Bob
More info would help!
Tire size?
Tire make?
Properly inflated?
Properly aligned?
What is the 'wear pattern'? Even or not?
Old May 28, 2003 | 07:31 AM
rbourne's Avatar
Re: Re: Tire wear
Tire size?
Tire make?
Properly inflated?
Properly aligned?
Tires are stock Bridgestone 225/50VR17.
Tires wear is even in the front and even in the rear.
Inflation currently at 30psi all around.
I consistantly get 26 MPG.
Current milage 26k.
Appreicate any ideas or comments.
Thanks,
Bob
Old May 28, 2003 | 07:34 AM
jjs's Avatar
jjs
Re: Re: Re: Tire wear
Current milage 26k.
Thanks,
Bob
How can "Tires wear is even in the front and even in the rear.", if your original post says the rears are wearing faster, are you saying the two fronts are the same, the two rears are the same, just the fronts and rears are not?
Also, how often do you rotate?
Old May 28, 2003 | 07:37 AM
255HP_03_SE's Avatar
and 30psi is LOW
should be around 35 or 36.
-R
Old May 28, 2003 | 07:42 AM
jjs's Avatar
jjs
Originally posted by 255HP_03_SE
and 30psi is LOW
-R
True, forgot to comment on that one. Still, for me 35-36 is a tad high.
Old May 28, 2003 | 07:43 AM
MaxAppeal's Avatar
Stop trucking around fat girls in your backseat. one word- Buspass.
Old May 28, 2003 | 07:50 AM
rbourne's Avatar
What I mean by even wear in front & back is both the left & right tires are evenly worn though different from the front to the back. And no I don't truck around "heavy loads" While 30 PSI may be low it doesn't account for the uneven wear since the front, having more weight, has maybe 20% more tread than the rear. I've always seen more wear on the front of all my cars.
Bob
Old May 28, 2003 | 07:58 AM
MaximaMan77's Avatar
Bob
At 26k miles I believe you would have had you tires rotated at least 3 times by now. If 3 is the number you now have the original fronts on the back and they have been up front twice.
Old May 28, 2003 | 08:05 AM
rbourne's Avatar
No, I've not rotated my tires at all, hence the reason why the rear wear is so strange.
Old May 28, 2003 | 08:07 AM
Who services your car?
Old May 28, 2003 | 08:13 AM
MaxAppeal's Avatar
do you back out of a very very long driveway?
i've never encountered this mystery... good luck cause i have no idea; hence, my idiot responses
Old May 28, 2003 | 08:16 AM
jjs's Avatar
jjs
What about the wear pattern? Wearing evenly on each tire? More inside gone? Outer edges going?
Old May 28, 2003 | 08:21 AM
rbourne's Avatar
Each tire is worn evenly though slightly more wear on the outer edges of the rears. And no I don't take mad turns or have a long driveway.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
