one headlight brighter than the other!
Old May 29, 2003 | 06:37 AM
Darius's Avatar
I posted a few days ago about how my xenon bulb burnt out in my left headlight, and now that headlight is not as bright as the other one. I put the halogens back in and when you stand far enough away, you can definitely tell that one is brighter. It seems like the left one is on low beam and the right is on high beam, and when i high beam, they switch.... any idea whats going on?
Old May 29, 2003 | 06:43 AM
saxdogg's Avatar
Are you sure it's not the different alignments of the lights you're seeing? Isn't the right HL aimed a little higher to light the roadside?
Don't quote me on that. I guess check their alignment maybe???
ARFF
Old May 29, 2003 | 06:53 AM
skandalouz's Avatar
yeah...for some reason my right headlight is aimed a little higher too
Old May 29, 2003 | 07:19 AM
slickrick's Avatar
i believe the left headlight is aimed slightly lower to reduce glare for oncoming drivers.
Old May 29, 2003 | 03:54 PM
WHEELMAN_03_SE's Avatar
with the hids on a 2k2/3 the right light is aimed a little higher so that it points more toward the road signs and the left one lower so the light doesnt blind oncoming dirvers because our HID low beams are brighter than most halogen high beams at certain angles
WHEELMAN
Old May 29, 2003 | 04:16 PM
jesse's Avatar
VTEC This!
yeah, i had the same prob, just mess with the alignment...pull the car up to a wall so you can see better
Old May 29, 2003 | 05:16 PM
Darius's Avatar
yea i know about the slight difference in aiming, but this is really noticeable... and i only noticed it since that xenon burned out in the left HL. How do i mess with the alignment?
Old May 29, 2003 | 07:04 PM
jnm2kse's Avatar
WHEELMAN
It is the same on 2k and 2k1... I thought my lights were not aligned
Old May 29, 2003 | 09:50 PM
pana69's Avatar
I was having that problem when I putin the bright lights, so I got a wire harness from SUVLIGHTS.COM
it gives more power to both headlights and it also prevents the melting wires from the higher wattage bulbs
Old May 29, 2003 | 09:52 PM
jesse's Avatar
VTEC This!
theres a little white **** on the back of the lights, use a wrench or somethign to turn it
Old May 29, 2003 | 11:43 PM
mclee45's Avatar
i have the same problem.. my left light is twice as bright. i dont know but i keep burning the bulb on my left headlamp that is why i'm lookin for some real HIDs. i bought like 5 sets of bulbs already in the 3 year life of my car. and its the left bulb that keeps burning out. anyone know why?
Old May 30, 2003 | 09:38 AM
WVmax's Avatar
Yeah, on my 2K, one of the first things I noticed was that the right headlight pointed higher than the left. I thought maybe it was just out of line, but now I guess it's purposefully that way. Saves me a little time correcting it then.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
