Spring Install Question
Old May 29, 2003 | 08:40 AM
2k2nyc's Avatar
When installing springs, did you guys insulate the top of the coil w/ rubber like the bottom. I was told that this is sometomes done on Maximas and that's how mine were installed; but when it's humid or raining out it feels like my spring/strut assembly is moving around, causing a lot of clunking.
Old May 29, 2003 | 08:42 AM
maxxximus's Avatar
Same here, I just assumed that it was my shock gone bad. Did you upgrade springs on stock shocks?
Old May 29, 2003 | 08:45 AM
2k2nyc's Avatar
I have H&R's and Tokico's.
Old May 29, 2003 | 12:42 PM
WildmanAL's Avatar
I didn't insulate the top of the spring like I did to the bottom and mine don't clunk. Maybe they springs aren't sitting right on your strut.
Old May 29, 2003 | 12:47 PM
njmaxseltd's Avatar
Spring isloators should go on the bottom coil and the second coil down from the top.
The strut bearings keep the assembly rotating freely. If it was damaged or installed incorreclty your spring would bind and make noises as you turned your steering wheel.
Old May 29, 2003 | 01:00 PM
2k2nyc's Avatar
I guess I know what the problem is then, thanks.
dank4us
34
Jun 10, 2024 03:45 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
95Maxi
35
Sep 2, 2015 10:37 AM
Economic_Rage
Aug 20, 2015 08:27 AM
