Is there any way to disable all the rear lights with one switch
May 30, 2003 | 06:43 AM
I want to wire my rear lights to a switch. That way I can flip a switch and the taillights, brakelights, licsense plate light, and spoiler light will all be disabled.
May 30, 2003 | 06:46 AM
turn off the headlights!! or are you trying to run from cops at night??
May 30, 2003 | 06:49 AM
May 30, 2003 | 06:50 AM
Quote:
May 30, 2003 | 06:54 AM
Quote:
Originally posted by NT2SHBBY
Why else would you want all you rear lights out? w/o just turning off the headlights?
running from cops is all i can think of.
May 30, 2003 | 06:56 AM
...or a drug deal that went bad...
May 30, 2003 | 06:58 AM
hey lumbee...ever thought about just gettin a smoked plate cover? and wiring ur reverse lights on as constant with a switch?
May 30, 2003 | 07:00 AM
It can be done with relays, but I dunno why you would want to. If you aren't "electrical" then you won't be able to do it yourself.
May 30, 2003 | 07:01 AM
sounds a little fishy! and maybe kinda illegal (but so are my clear corners)
May 30, 2003 | 07:02 AM
so is speeding, but that don't stop u does it?? don't stop me!!
May 30, 2003 | 07:03 AM
Re: Is there any way to disable all the rear lights with one switch
Quote:
You can, but if you get caught, its illegal and you WILL get in serious trouble.
May 30, 2003 | 07:09 AM
yes but i think he will get in ALOT more trouble for this. mutliple citations (maybe one for each light not working). then citations for whatever he is doing that gives him the need to do this (speeding, wreckless driving, evading arrest?). im thinking if he gets caught he might just get taken in.
May 30, 2003 | 07:35 AM
Back in the day I had this done to my 91 Accord. A good friend of mine wired it for me. As I can recall it was a whole bunch of relays that were triggered by a switch. In my car it would blackout the whole rear end of the car. In my friends case (on his Eclipse) he had another switch that would blackout interior lights as well.
Why did I do it? well I could come up with a bunch of BS to justify the reason but honestly I truly thought it would help me run from a cop (no drug deals here people, just to avoid a speeding ticket). I did manage to escape from a cop (speeding ticket) but the light-blackout system didnt help since it was during the day! Needless to say that was pure luck and nothing more and I have never attempted to pull such a stupid stunt ever again in my life! and nor will I ever think about doing so again! (I think of it as Quitting while I am ahead )
May 30, 2003 | 08:32 AM
Just shut your headlights off and drive holding your high beams swich on.
May 30, 2003 | 08:34 AM
Quote:
that wouldnt help with your brake lights though.
May 30, 2003 | 09:03 AM
I always wanted something that would cover my license plate with the flip of a switch to avoid photo radar. You have 3 full seconds to react after they take the picture of your face before they snap the one of your rear license plate. I could never get anything engineered though.
May 30, 2003 | 09:17 AM
Quote:
Yes it would.. When you shut your lights off (I mean all the lights off) and just hold your high beam switch back the tails go out. Then you have just your high and low beams on, everything else is off
May 30, 2003 | 09:47 AM
sorry dude not meaning to argue with you at all... but when you step on the brakes your brake lights will still light up. the headlights only control the secondary/marker lights, the primary brake lights are not controlled by the headlight switch and is only controlled by the brake switch and thus will still light up. Unless you use the hand brakes. (In some cars even the hand-brake is rigged to the brake lights so the brake lights light-up with the hand brake application with the keys on. When no key is in the ignition they dont.)
May 30, 2003 | 09:52 AM
it would be a huge pain but u would need to tap into all of the red wires to all the lights and run them back to a switch and run new wires to the red wires from the switch to the lights.
PAIN IN THE @ss but it is possible
May 30, 2003 | 09:55 AM
Yeah, that is the "pain n the a$$ method." It would be much easier to use a bank of relays and switch the grounds on the rear lights. Minimal voltage drop issues this way.
May 30, 2003 | 10:00 AM
PAIN IN THE @ss? I agree...
I am not an electronic expert here (not even close) but for example, couldnt you just install relay(s) on the ground connection to all of the tail lamps and just trigger the relay to connect/disconnect the ground connection, by controlling the relay via a switch inside the car?
Or if controlling the ground connection is not possible then couldnt you just put a relay on every positive connection to the lamps and use one switch to trigger all of the relays on/off? (dont have to wire each and everyone of the positive wires to the switch) just ONE wire that triggers all of the relays?
I am probably way over my head here... but just a thought
May 30, 2003 | 10:01 AM
t56gen3
haha you beat me to it. but good to know that my idea might actually work! haha
May 30, 2003 | 10:04 AM
Re: ..
t56gen3
Yep, it would work just fine. Even easier if they all share the same ground (which I doubt is the case.) Either way I'm sure there will be less grounds than positives.
May 30, 2003 | 10:07 AM
here is how to do it
TURN OFF YOUR CAR!!!
May 30, 2003 | 10:15 AM
Quote:
I believe there is a plate cover out there that makes it so it can only be read directly from the back. Any other angle and it's blurred.
May 30, 2003 | 10:23 AM
Yeah, and I always wanted a tailpipe that spits out smoke and/or oil, rims with retractable knives, and fenders with pop-out rockets launchers. Oh, and all in an Aston Martin DB5.
May 30, 2003 | 10:29 AM
if any one has seen "the transporter", i want a bmw like that. he had to enter a code to start it and he could push a button and the plate would flip over to another plate. very cool, IN A MOVIE!!!
May 30, 2003 | 10:30 AM
I can see it now, forget to flip the switch again, get hit from the rear, totals your car and you get to be responsible because your car has faulty equipment.
May 30, 2003 | 10:31 AM
Quote:
Yeah man, like what he said! lol
May 30, 2003 | 10:35 AM
EXACTLY! especially when your forgetful like me. Thats why I never did anything like that to any other of my cars. It's just a bad idea.
May 30, 2003 | 11:30 AM
where is the guy that started this? he needs to explain WHY he wants to do this!!
May 30, 2003 | 11:43 AM
Would you come back to endure this abuse?
May 30, 2003 | 11:49 AM
run from cops much?
May 30, 2003 | 11:51 AM
why not just spend $250,000 cop a Porsche GT2 and no cop will EVER catch you....they'll just set up tire spikes and a road block!
May 30, 2003 | 12:18 PM
Quote:
true, now he is scared to come back. stupid question!
May 30, 2003 | 02:41 PM
He'll also need a surface to air missile system installed on the roof to shoot down the police helicopter who can track him in spite of his tail lights being out.
May 30, 2003 | 02:43 PM
Quote:
Porsche GT2
Won't out-run a helicopter.
May 30, 2003 | 02:50 PM
You can always down shift If I am doing something realy dumb and need to kill my tails (liscense plate is the only thing I want to hide) I usualy won't be hitting the brakes any time soon, so I just kill the lights and use just my high beam system.
Quote:
aint that a 8itch
May 30, 2003 | 02:56 PM
Quote:
Originally posted by skandalouz
run from cops much?
