Accessory Fog Kit
Old Jan 26, 2001 | 03:02 PM
maxamillion
I have seen the messages of the fog lights and how to install them, but have not heard anyone talk about where their fog light switch is mounted from the factory kit.
I saw the SE and GLE with the Fog option and they are mounted on the stalk.
Where is the switch located if you buy the factory fog light kit (about $180) ?
Old Jan 26, 2001 | 03:09 PM
MaxDoogie's Avatar
When you get the factory fog light kit, it comes with a whole new haed light switch assembly. So, when you install the headlights, you have to remove the old headlight switch assembly and put the new one with the fog light switch. The whole assebly goes pretty quick and can easily be done in under two hours.
Old Jan 26, 2001 | 03:23 PM
maxamillion
BUMMER, Does that mean that I am stuck like everyone else so I can't run the Fogs with the high beams unless I use that bypass jumper trick in the fuse box?
Looks like I might need to go aftermarket so I can mount a switch in one of the accessory slots on the dash... Second thought, I want a factory look and not a cobbled piece of schist. Oh Well.
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
