Painting calipers with engine spray paint?
Old Jun 2, 2003 | 09:59 PM
Jeff2k1GLE's Avatar
has this been done before? or should i just go for the foliatec caliper paint?
releasedtruth's Avatar
rilla dope
Pep boys 6 dollar caliper paint. Works just as good, trust me. Even in AZ heat it's solid
Old Jun 2, 2003 | 10:09 PM
Jeff2k1GLE's Avatar
is this a spray paint?
Old Jun 2, 2003 | 10:30 PM
irvine78's Avatar
i just used high temperature paint...like the ones you use to paint engine parts...works just as good IMHO.
Old Jun 2, 2003 | 10:41 PM
Jeff2k1GLE's Avatar
ok i think i'm gonna go with that.. thanks
Old Jun 2, 2003 | 11:39 PM
Y2KSESteve's Avatar
Does this dry faster than the Foliatec? I never even thought of this...
Old Jun 2, 2003 | 11:52 PM
irvine78's Avatar
yes, it dries faster than Foliatec.
Old Jun 2, 2003 | 11:54 PM
Y2KSESteve's Avatar
Sweeeet! Did you use a high temp clear coat as well?
Old Jun 3, 2003 | 12:57 AM
Triple8Sol's Avatar
I miss the .org!
I used high-temp Duplicolor engine enamel. It works great. Just make sure whatever you use is high temp, and allow it to dry properly before rollin'...
Old Jun 3, 2003 | 05:03 AM
optimus1's Avatar
why
let it cure after a 100 mph quick stop, .. a couple of times, if your rotors can take it ...
Old Jun 3, 2003 | 06:12 AM
255HP_03_SE's Avatar
See if it stands up to MN/IL cold... the salt from the winter roads... acid rain from the city...
Serious. You get what you pay for. Ask Speedy6. He painted his calipers with the 'cheaper' paint and they now look a little faded. My Foliatec paint doesn't fade... and I am going to help Speedy redo his calipers.
_R
Old Jun 3, 2003 | 06:37 AM
rilla dope
_R
Whatever makes you feel good about a 40 dollar can of paint my friend. I have friends back east, up north, down south, all using cheap pep boys type paint. One can was enough to coat 8 calipers 4 times. Dried pretty quick too and it's been black as night for a year so far and others for much longer. And even if it ever fades, 6 bucks more and you can add 8 more coats to each of the 4
Old Jun 3, 2003 | 09:56 PM
ajahearn's Avatar
Here in Northern Cal, I used high temp paint. Works okay but doesn't stand up to any kind of abuse (changing pads, etc.). Of course its about a 15 second job to touch it up though. If the salt/rain/etc. does really take its toll you might want to consider something like Foliatec. Its a bit of a pain to take the wheels off, clean the calipers, etc. Probably be worth the extra $30-40 not to have to repeat the process.
Old Jun 3, 2003 | 10:47 PM
K Pazzo 6's Avatar
sorry i cant help b/c i used the foliatec but just wanted to say your car looks phat w/ the stillen kit
Old Jun 6, 2003 | 12:50 PM
Jeff2k1GLE's Avatar
thanks bro, just had it put on monday
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
16_SR
Sep 9, 2015 07:14 PM
Hdnseek
Sep 9, 2015 05:55 AM
beerman1378
Sep 8, 2015 02:19 PM
