Moon Roof problems?
Old Jan 27, 2001 | 01:32 PM
Avatar
Has anyone had any problems with it? Leaks, motor, etc?
Old Jan 27, 2001 | 01:35 PM
max2k1SE's Avatar
Nope - seems to work just fine with me...
no leaks for sure - did drive it a lot during rains
motor has been ok till now -- i hope it stays that way ( with the TSB on the tranny, anything's possible ! )
Old Jan 27, 2001 | 01:54 PM
edadams's Avatar
Works Good, although if it is raining or wet you can hear some suction noises, but I have not found any leaks. I drove a 2001 altima the other day while raining and it does the same as my max.
Old Jan 27, 2001 | 01:59 PM
Proceedbob's Avatar
No, although closing the shade at highway speeds reduces road noises little. Does anyone have the wind deflector, and are you happy with the look?
Old Jan 27, 2001 | 02:08 PM
Oiprocs
I have it...
I have the wind deflector. What I have found it to do is keep that ANNOYING "choppy" noise you get with sunroofs at high speeds while other windows are shut. It also looks nice (I think) head on. You can see it elevated from the top of the roof, showing you have the sunroof and just gives it a nice "sporty" look, again, I think. But aside from looks, I think it works good. I never knew it was for function...but it sure does cut out that annoying wind noise!
Old Jan 27, 2001 | 02:56 PM
UMD_MaxSE's Avatar
Got Bent?
No problems here....I need to get a deflector though...
Old Jan 27, 2001 | 03:36 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
No probs here...
Old Jan 28, 2001 | 02:56 AM
warrlocked's Avatar
No problems at all. I highly recommend the wind deflector it does make a difference. DO NOT BUY A DEFLECTOR FROM YOUR DEALER they will over charge you. Buy one from Courtesy Nissan.
A friend of mine owns a '91 Nissan Sentra SE-R with a sunroof. He uses his a lot ..everytime it is at least 60 degrees and not raining...and he hasn't had any trouble whatsoever. His experience makes me feel better about Nissan roofs.
Courtesy Nissan:
http://www.courtesyparts.com
[Edited by warrlocked on 01-28-2001 at 05:15 AM]
Old Jan 28, 2001 | 03:41 AM
Maxima-Ness's Avatar
OMG! I was driving my Max down the highway and as i sped up to around 90 the sunroof started vibrating violently and i remember lookig up and seeing it try to pull back but you could hear the motor making noise trying to keep it shut so i slowed down and got off on the next exit ramp and after that, it never happened again.........j/k
No problems here!
Old Jan 28, 2001 | 02:07 PM
MaximaKev's Avatar
Problems
I've had a problem...here it is
Got in one day to open the roof and it only opens about 1/5 of the way. So I flip the slide back switch 5 times to get it all the way open. When I go to close it, it goes past the close position and begins to tilt up. Keep in mind I was only using the slide switch. More investigation...both buttons now do both functions, but poorly might I add.
Anyways, the dealer replaced the motor/control module assembly after multiple visits, but I got it fixed under warranty. Man, dealerships can be real idiots. I investigated on my own and found out what the problem was and told them, and they still didn't fix it the first time...
I also recommend the wind deflector. I like the looks and it defintely cuts back on the wind buffeting. Much quieter with the roof open now. Also, no leaks!
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
homewrecker
Sep 24, 2015 07:01 PM
