Radio and Clock went out? Help
The radio went out while I was listening to a CD as well as the clock. I checked all the fuses and they are OK. The radio buttons light up but won't accept any cd's or play the radio and the display won't light up. What's the deal?
Re: Radio and Clock went out? Help
Test the fuses with the ignition ON and with a Voltmeter only! Hope that helps.
Re: Re: Radio and Clock went out? Help
The cigarette lighter works as I have a radar detector hooked up to it. I checked all the fuse, including fues under the hood and under the driver side. It might be a loose wire.
Originally posted by t56gen3
Sounds like you blew a fuse. There is a fusebox under the hood as well as the dash. The radio has a constant +12v fuse as well as a ignition-switched power on fuse. Dunno for sure on the Max, but most the time the cig lighter is on the same fuse as the constant +12v, and usually under the hood. Many times I have seen a coin get dropped in the cig lighter, especially if it's close to the ashtray, and short out the fuse. Check both. Lights should still come on with the parking lights (different circuit.)
Re: Re: Re: Radio and Clock went out? Help
Originally posted by Max2000SE
Same here except its my dash lights...ALl fuses are fine..Guess I gotta waste more time at NIssan
Originally posted by HondaKilLR
Find that little wheel thing right next to your side mirror adjustment. Turn it all the way to the right. Peace...
t6378tp
Sep 29, 2018 04:27 PM
