Who has the fastest 5th gen on the board?
Old Jun 11, 2003 | 01:39 PM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Originally posted by blubyu2k2
Hey...you ever look into that "drop resistor" thingy the 4th gen automagics do to get full lockup at WOT?
Jime has that, but I'm wondering if you would benefit IF it's possible for a 5th gen..
Old Jun 11, 2003 | 01:48 PM
  #42
Blu's Avatar
Blu
the tits
yes its possible but on the 02-03's it will trip the cel and have to get the ecu flashed to get it cut off. I believe so anyway
Old Jun 11, 2003 | 02:15 PM
  #43
2K2_6spd's Avatar
Was that at Firebird? If so, I can guarantee if you ran at BabyBlu's track you would run 13's.
Firebird is F'ing slow compared to those East coast DOWNhill tracks.
Yes, that was run at Fireturd.
Old Jun 11, 2003 | 06:48 PM
  #44
KLOOGY's Avatar
L33t BMW Drivah
Im pretty sure most Autos would be in the high 13's with slicks, considering most of us spin all through first gear, and start hooking up in second.... even on big wheels...
That track you ran at Blu seems to be a rocket of a track. I have run at Englishtown in my stang before, and it was pretty good. The tracks out here in Cali suckk monkey ***** !
Old Jun 11, 2003 | 07:15 PM
  #45
emax02's Avatar
Originally posted by SR20DEN
And with Dave B in your car with slicks at our track it would be 12.3.
So true
Old Jun 11, 2003 | 07:28 PM
  #46
emax02's Avatar
Originally posted by HitManSE
Wow so no slicks, well I guess its been a while since you made that post since I dont remember what you had . Still very impressive. Now few things that im trying to add up, first did your stock 17's have the RE92 potenzas that came stock? The reason I ask is I personally dont think they provide enough bite for a good launch, if you were using another brand, what kind was it that gave enough bite for a sub 14 run? One last thing, are motor mounts an issue at all? epsecially with slicks? Will the 4th gen polyurethane mounts from cattman fit? (I think they do, but want some confirmation )
Mods at the time where frankentake, UR UDP, Stillen Y-pipe, RT cat, Greddy exhaust. Since then for performance I added franken car mounts and Denso Iridium plugs.
I ran on my stock 17' rims with stock potenzas. I put the potenzas down to 22 PSI up front. My 60' on my 13.8 run was a 2.251. I added the franken car engine mounts over the winter, I have not been able to test them out yet. I am not sure about the cattman mounts fitting, I think they probably would fit though.
Hopefully the mounts will knock .05 off of my 60's, that would be great. They really cut the wheel hop down so I expect to see some good results.
Old Jun 11, 2003 | 09:01 PM
  #47
PearlRalizinG2k's Avatar
2000 gxe
15.136 @ 90.92 stock
15.121 @ 93.63 intake/exhaust + full audio and bad cutch dont know if the weight and the bad clutch had anything to do with it, but after those mods my time was too similar as stock
Old Jun 11, 2003 | 09:07 PM
  #48
HitManSE's Avatar
Well atleast the frankencar mounts are an option. Thanks for the info and I guess you'll by lowering your ET again this coming winter, good luck.
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 23, 2015 03:38 PM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
