Rsb - Clunk!
Old Jun 12, 2003 | 05:20 AM
cmr72's Avatar
Rsb - Clunk!
Hey all,
I am getting a nice clunking noise when I go over railroad tracks, speed bumps, etc. only on the passenger side. Please check out my photos and let me know if I have the brackets too close to the "curve" in the RSB.
http://photos.yahoo.com/cmr5972
Old Jun 12, 2003 | 05:28 AM
Virus's Avatar
Holy crap how can you see anything on those dark pics? Try moving them in a couple inches. They should be 4 to 4.5 inches from the curve.
Old Jun 12, 2003 | 05:40 AM
cmr72's Avatar
Took them last night in the dark...had to guess where the brackets were because I couldn't see anything...
Old Jun 12, 2003 | 05:42 AM
PCGuRu2K's Avatar
Make sure the bar is not like directly under that "U". Mines was like a lil behind it and it was hitting. So I moved it like an inch foward.
Old Jun 12, 2003 | 06:03 AM
cmr72's Avatar
Ohh...never thought of that...will look tonight. I don't think I have any room to move it up...I only had about 1/2 inch exposed on the side brackets near the brake lines.
Old Jun 12, 2003 | 06:36 AM
2001SE's Avatar
what exactly do you mean by "U"...u bolt? bracket?
Old Jun 12, 2003 | 07:03 AM
cmr72's Avatar
In the center of the RSB in my picture, there is a piece of metal coming down that has a "U" shape...
Old Jun 12, 2003 | 07:28 AM
MaximaMan77's Avatar
That "U" shaped thing is part of the rear suspension it's (I believe) the swing arm pivot point for the rear beam. The RSB can't go much more than an inch past the beam axel or when you hit any medium to large bump the RSB will make contact with the that bracket/hinge. What PCGuRu2K means is moving the whole RSB forward till it's under the axle, not moving it up. You need to loosen all the bolts and slide it forward some and you'll be fine.
Old Jun 12, 2003 | 07:54 AM
maxcosity's Avatar
My RSB used to clunk, and I found out it was just a loose bolt that was holding the RSB on.
Old Jun 12, 2003 | 07:58 AM
Maximax2's Avatar
It's called the Panhard bar. The RSB should be directly under the multi-beam; assuming it is, move the RSB brackets that are located on the multi-beam (not the trailing arms) toward the center a few inches. That should fix it. Note that the How-To's describe this problem and how to resolve it (with pics).
Old Jun 12, 2003 | 07:59 AM
PCGuRu2K's Avatar
Exactly
Old Jun 12, 2003 | 08:17 AM
cmr72's Avatar
Yeah, they are exactly 4.5 inches from the "curve" but I believe that the bar needs to be pushed forward. Looking at my pics I see that the U-Bolt kind of tilts to the rear.
Unclejunebug
Apr 2, 2016 05:42 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
