allignment
Old Jun 14, 2003 | 03:19 PM
tecman4's Avatar
allignment
anyone ever have a problem with shaking inthe steering wheel and they did an allignment and it went away?
I've had a shaking in the steering wheel ever since I got the car it happens whenever I drive over 45mph.
I've had the wheels balenced many times and had 2 tires replaced.
twice with a hunter 9700..
I've rotated the rires also and the problem remains.
So i'm kind of at a loss as to what I should do next
Old Jun 14, 2003 | 04:00 PM
oldmanmax's Avatar
If the car is shaking, it's because the wheel is not balanced. May be the wheels is balanced but when it's put on the car, it's not. They may overtighned the wheels and cause it to be out of balance. It happened to me but I brought it back and they re-balance it again and it went away. Let's hope it's not wrong with your suspension...
Old Jun 14, 2003 | 04:24 PM
tecman4's Avatar
I thought the same thing but I brought it to 3 different shops who all say that the tires are balanced.
But thanks for the responce
Old Jun 14, 2003 | 05:10 PM
maseo77's Avatar
your wheels could have a slight bend in them, that would definately cause shaking
Old Jun 14, 2003 | 05:16 PM
MaxSE03's Avatar
That is true but there is a problem with that in this case. The vibration starts after 45mph. If he had a bent rim, they would not be able to balance it.
Old Jun 14, 2003 | 05:19 PM
tecman4's Avatar
could it be an allignment issue?
Old Jun 14, 2003 | 05:30 PM
maseo77's Avatar
i balanced 1 of my stock 17's after i hit a nasty pot hole and then i got vibrations just like what your talking about around 60 mph, so i drove like that for a few weeks and did the balance over again now i can barely feel it at 60mph much better but still there very slightly.. your rim is bent.... the only options are to replace the bent rim or rotate it to the passenger side rear of the car where u wont feel it at all. the best 2 rims should be put up front because the closer a bad wheel is to the steering wheel the more you feel it.
Old Jun 14, 2003 | 07:55 PM
tecman4's Avatar
I didn't hit anything and they said the rim doesnt look bent.
does a hunter 9700 check for bent rims?
DAVE Sz
Apr 13, 2004 11:02 AM
Greg 88 Floater
Aug 19, 2003 02:13 PM
JUDE
Apr 10, 2002 10:58 AM
amixam69
Jan 3, 2001 07:08 AM
