Question About Eibachs
Old Jan 29, 2001 | 05:22 PM
00DubbedMax
I don't know too much about this stuff, so I'll ask you guys. Is it necessary to change the struts and shocks when adding these springs? Or can I just use them with the factory shocks? Also, how is the ride quality going to be?Any advice and information would be greatly appreciated.
Old Jan 29, 2001 | 06:15 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
You don't have to change the struts, but it's recommended. I drove on the factory struts for a long time and had no problems. The ride quality will get bad (very bumpy and harsh), but I personally don't mind it at all.
When you get them, make sure you have the installer cut your bump stops. The instructions should tell you, but I want to give you a heads up first.
Old Jan 29, 2001 | 06:43 PM
00DubbedMax
Will do..Thanks for the info Kev.
-Greg
Old Jan 29, 2001 | 07:00 PM
68Stang's Avatar
Coilovers greg. go for tha 3" drop on the dubs.
Old Jan 29, 2001 | 07:04 PM
Albertan's Avatar
Ummm...I cannot comment on the Tokicos since I have been on the factory struts since installing my Eibachs. So far as I am concerned they work fine. The ride is definitely alot stiffer, but thats part and parcel of the deal, and to be honest I prefer the ride cause it "just feels right" to me. I thought "Hell I have the SE sport suspension. How much better can the mods be?" ALOT. Just be aware that that it is a markedly stiffer ride. Maybe look into the H&R's if that concerns you. Oh BTW, the car looks MUCH better lowered with the Eibachs. That alone is almost reason enough to do it.
Y2KevSE - I was actually just minutes ago thinking about emailing you with this question but I'll just put it here since it ties in so nicely. How do you find the Tokicos compared to the stock struts with the Eibachs? I have all the other suspension mods you have listed and was just wondering if you really felt the Tokicos are necessary/worth it. Thanks for the info.
Old Jan 29, 2001 | 07:17 PM
Y2KevSE's Avatar
The Tokico Blue's definitely softened up the ride a bit. It's not as bumpy as before, but still bumpy enough for you to go to the restroom if you drank a lot of water. I'd say they are worth it, but I haven't felt the Koni's yet so I can't say which set I should've bought. Changing the struts aren't necessary, IMHO, because I felt I could've driven longer with the stockers, but they'll definitely help the ride quality.
Old Jan 29, 2001 | 07:21 PM
Albertan's Avatar
Wow! That's a quick reply. Thanks for your feedback. Where did you get the Tokicos and what did they cost. I am a bit out of the loop around here now. Basically thoough I kinda like the ride as I mentioned with the stockers and see no point in firing a bunch of perfectly good struts with 2500 miles on them onto the spare parts shelf in the garage. But hey a mods a mod...
Old Jan 29, 2001 | 07:56 PM
Albertan's Avatar
Old Jan 29, 2001 | 10:45 PM
Y2KevSE's Avatar
There's a thread in here (pretty recent) listing the prices of the Tokico's... try searching for it.
Old Jan 29, 2001 | 10:58 PM
Maxx-s-ter's Avatar
change
your springs and struts the same time. you will save on the Labor. You WILL want to replace the stock struts after a while with the Eibachs. The stocks struts can't handle the stiffer spring rates, so after a while your ride will get worse. do it now if you have the $$$$. I paid $280.00 for tokicos from stillin. Not bad.
Old Jan 30, 2001 | 06:36 AM
punkdork's Avatar
Pardon my ignorance Grand Master, what are bump stops?
Old Jan 30, 2001 | 06:42 AM
yongjun's Avatar
Ground control coil over kit $399.00
Eibach $219.00
H&R $239.00
Koni doesn't make them for the 2000 model
Tokico's are $324.00
set of 4
There ya go
Old Jan 30, 2001 | 06:45 AM
punkdork's Avatar
Eibach $219.00
H&R $239.00
set of 4
There ya go
Thats no description of a bump stomp YJ. Go to school and do something usefull!
Old Jan 30, 2001 | 06:46 AM
yongjun's Avatar
yea i need to get to school.
gotta wait for my friend to get ready so i can take his ugly *** to school too
Old Jan 30, 2001 | 07:50 AM
Y2KevSE's Avatar
Are you mocking me? I know you're mocking me! Bad punkdork!!! punkdork . . . . . . . .
They are hard foam/rubber pieces that go in your strut boots to keep your car from bottoming out (the bump stops for your rear struts are attached to the boot so you'll have to cut your boots). You cut them so it'll give you more suspension travel. If you lower your car and not cut the pieces (giving you less distance for your struts to compress), you're not utilizing the full potential of your springs.
That's my crash course, hope that helps.
Old Jan 30, 2001 | 09:04 AM
punkdork's Avatar
So will that void the warranty any more than putting on the lowering springs?
Old Jan 30, 2001 | 10:20 AM
Y2KevSE's Avatar
The only way they can tell if you've modified the bump stops is to pull out your front strut assemblies. For the rears, buy new boots if you REALLY need them.
The springs would only void the struts warranty if the dealer is really **** about aftermarket stuff.
Old Jan 30, 2001 | 10:58 AM
punkdork's Avatar
Cool... the name bump stop makes it sound important... like I'll get a low rider truck kind of ride if I have em cut. Heh... you wanna help me put in some hydraulics and loads of gold trim?
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
