Mileage Difference with 235/45/17
Old Jun 19, 2003 | 12:58 PM
MaxJag's Avatar
I checked the tire calculator and it said "Speedometer reading with non stock tire is 2.1% too fast. When your speedo said 60mph you are actually traveling 58.8mph.
My question is does this mean your car accumulates more or less miles than normal on the odometer?
Old Jun 19, 2003 | 01:01 PM
2k2nyc's Avatar
You accumulate more, when you've done 100 miles your odometer records 102.1 miles.
Old Jun 19, 2003 | 01:11 PM
2kseman's Avatar
yep, you accumulate milage a little faster, however, the other side effect is that your gearing is a little taller....giving you quicker acceleration...
Old Jun 19, 2003 | 01:14 PM
jjs's Avatar
jjs
Re: Mileage Difference with 235/45/17
Since it is off only 2.1% this is pretty much insignificant (at least to me) an issue.
Think about it...by 100,000 miles you will be 'off' only 2,100.
Old Jun 19, 2003 | 01:21 PM
2k2nyc's Avatar
I'm running 245/45/18, mine is off by more than 3% too slow, but it doesn't really bother me
Old Jun 19, 2003 | 01:27 PM
MaximaMan77's Avatar
Isn't there a way to reset/adjust the speedo? No it's not that big of a deal but the next time you need service at a dealer they should be able to adjust it, if it bothers you that much.
Old Jun 19, 2003 | 01:30 PM
jjs's Avatar
jjs
You know, the other interesting thing is that these 'speedo errors' don't address at all the inherent margin for error of the (mass produced...often by the lowest bidder) speedo calibration itself, nor does it address the different speedo readings as time goes on due to simple tire wear. As they wear, tires are no longer the exact same diameter as when new, so right there you are talking about inherent error rates.
Bottom line to me is unless it is WAYYYYY off, who cares!!
Old Jun 19, 2003 | 01:49 PM
MaxJag's Avatar
Thanks for all the quick replys. I now feel a whole lot better on the situation. Your right! Who Cares!! I will be getting the Kuhmo Escta MX's thanks to Mr. JJS!!! Thanks for all the helpful information bro!
Old Jun 19, 2003 | 01:51 PM
jjs's Avatar
jjs
No way man!!!! I just gave you some pitfalls/concerns...you picked 'em!!!!
Enjoy!!
Old Jun 19, 2003 | 01:56 PM
MaxJag's Avatar
It was these or the 245/45's. I heard the 235's are better in width than the 245's for OEM 17's.
I think I'll be alright. Others are running the same setup.
Thanks again.
Enjoy!!
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
