fuel injectors
Old Jun 23, 2003 | 08:52 PM
3000GT's Avatar
fuel injectors
i drive a 97- with a s.ced 2000 motor. question is--does anyone know if the 2001 or up motors fuel injectors will fit in the 2000 motor? i am assuming that the new motor injectors flow more (for larger displacement motors) and are also the higher impedence type?? any info would be cool/ i just dont want to push the 2000 injectors to or past their duty cycle. thanx in adv.
Old Jun 23, 2003 | 08:58 PM
BigDogJonx's Avatar
2001 is still the same as the 2000, 2002 injectors dont fit in the 2001 cause its actually slightly different.
Right now no one makes out the box larger injectors, unless you get RC engineering to design you a set.
Dixit
Old Jun 24, 2003 | 01:50 PM
[maxi-overdose]'s Avatar
Re: fuel injectors
how much boost are you running? I think you dont need to upgrade your injectors if you are running less than 12psi. most injectors are unstalbe after 65psi of fuel pressure and I've seen 110+ psi on my gauge.
Old Jun 24, 2003 | 01:51 PM
Re: fuel injectors
how much boost are you running? I think you dont need to upgrade your injectors if you are running less than 12psi of boost. most injectors are unstalbe after 65psi of fuel pressure and I've seen 110+ psi on my gauge.
Old Jun 24, 2003 | 02:08 PM
3000GT's Avatar
Re: Re: fuel injectors
right now im going to estimate @12 to 14 psi. even though its intercooled ive got a 2.87 on an s-trim. i think ill be ok now but i also had planned to run a progressive nitrous kit.
Old Jun 24, 2003 | 05:35 PM
wantasupra3's Avatar
Re: Re: Re: fuel injectors
Dang! thats gonna put out some crazy numbers!
Old Jun 24, 2003 | 05:51 PM
the previous owner of my SC kit was running 2.87, 13psi for daily driving. he had water injection. I am also running a 2.87 but I loose the BOV and am running 10psi peak.
anyways, 5th gen (2k,2k1) injectors are side feed and 300zxTT injectors are top feed. as Dixit mentioned that there's no bigger aftermarket injectors made for us. I would check the spark plug to see how's the car running. Also if you have a good A/F gauge or EGT...you can tell if your car is running lean.
to detect detonating....you can always build a cheap stethoscope.
here is the link to the how-to
http://www.autospeed.com/cms/article.html?&A=0353
drop by SC/TC forum if you have time.
Old Jun 24, 2003 | 09:59 PM
3000GT's Avatar
Re: Re: Re: Re: fuel injectors
think you wrote the top feed side feed backwards-anyways-right now im not worried-have it tuned well but like i said before, i dont want to push too hard when all the goodies are go. thanks for the info though-ill try to scope the dealer about the 2002+ injectors.
Old Jun 24, 2003 | 11:01 PM
Re: Re: Re: Re: Re: fuel injectors
thx for the correction
good luck on the 2k2+ injectors and keep us updated!
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
