E-brake boot issue
Old Jun 24, 2003 | 12:59 PM
NoMotive's Avatar
E-brake boot issue
So i've got the new momo-carbon brake handle, looks great but the boot is a nasty fit. Im resorting to gluing velcro strips around the e-brake slot just to get the boot to stay. However, i got curious and tried taking out the rubber fitting around the base of the handle and now can't put it back properly. There are little stubs on the underside of the plastic center console which the rubber piece snaps onto. This is a problem because the e-brake will sometimes tug onto the loose rubber fitting and pull it down into the slot making it impossible to fully disengage the brake. Bleh It appears the only way i can get it to fit is to take the whole console out... Any suggestions?
Old Jun 24, 2003 | 01:08 PM
Colonel's Avatar
Old Fuddy Duddy
Re: E-brake boot issue
Yeah...you are sorta in trouble. Youll have to pull the whole center panel out to try and fix it. Trust me if you did not pull it in the first place and just yanked it out...its not going back. Get a leather ebrake boot from Eric at leatherseats.com, pull the center console and then install that instead. Its not going to be worth your time to reinstall that plastic boot.
Basically when you yanked it off, it shears the tops off so the rubber one will not "stay" in place. Trust me...experience.
Old Jun 24, 2003 | 01:25 PM
NoMotive's Avatar
Re: Re: E-brake boot issue
oh woe is me. That is the last time i fiddle with something that im not sure will fit back.
Mar 12, 2020 12:06 AM
followthadollar
Sep 17, 2015 06:31 PM
Bonka
Sep 14, 2015 11:18 PM
Violator
Sep 9, 2015 10:14 AM
beerman1378
Sep 8, 2015 02:19 PM
