Disappointed with track times, Also, SR20DEN please enter.......
Old Jun 28, 2003 | 06:26 AM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Ok I got 2 problems here.....
Well, I was at the LACR track ast night, got 3 runs, and the best time was a 13.89 elevation corrected. It was 87 degrees, 44% humidity, and 29.94 pressure.
Car was running like azz and my heater wasnt working so I was at 900 bottle pressure.
I wasnt feeling too bad becuase all the other imports were running HIGH 16s if lucky and 17s.
A Camaro z28 with 150 shot got a 13.6 and a camaro SS with a blower got only a 13.4.
dam this track sucks.
But to get to the point.. matt, SR20DEN, I did 2 really quick runs on the freeway before the track with the 125 shot and The car would go and kick nicely then when i'd let go, the timing would get retarded and the car would just be so f*cking slow.
This also happened to me about 2 weeks ago when my friend hit the button and let go twice under 3200 rpm. I guess the motor was trying to save itself. Do you know anything about this? Is nything like this happeneing to you?
THanks
Old Jun 28, 2003 | 04:03 PM
Eat Naaawwwzzzzz
matt?
Old Jun 28, 2003 | 04:06 PM
Maximam's Avatar
Did you correct all the other car times you quoted? You corrected yours.
Old Jun 28, 2003 | 05:08 PM
HitManSE's Avatar
Ive heard the tracks down in Cali really suck @ss but damn. Goodluck man.
Old Jun 28, 2003 | 05:23 PM
jtkz13's Avatar
Why not post the actual time you ran instead of correcting it?
Old Jun 28, 2003 | 06:21 PM
Eat Naaawwwzzzzz
14.42 was the best time
out of 3 runs, 2.38 was the only 60' they got since I sprayed to early in first and spun the rest of the gear.
The tracks suck ***..this one is 3000 feet high, very humid, pressure sucks, very hott, and to top it off, the track doesnt really much cleaning on the nights available to the public.
But I mean if Im only .8 seconds away from 150 shot nitrous z28, i did good...
Im getting slicks in a few weeks, thats should shave off a good second and some..
mattt where aree youuuuuuuuu
Old Jun 28, 2003 | 07:20 PM
KLOOGY's Avatar
L33t BMW Drivah
You should have run a lot better than that. Yes , most So Cal track suck huevos grandes ! You must have a serious issue somewhere, because 14.4 , even under those conditions sounds too wack... Matt to the rescue !
Old Jun 28, 2003 | 08:12 PM
Eat Naaawwwzzzzz
well like i was saying above...99% of the imports were going high 17s..
and the nitrous and supercharged camaros were going 13.4's so im sure it was a track issue....
my car was f*cking pulling though! I was sure i hit low 13s,
giavoni, wehre did you run your 14.7 and what was the actual uncorrected time?
Old Jun 28, 2003 | 08:18 PM
SR20DEN's Avatar
VQ Wizard
I never had a timing problem. My car always pulled like a SOB at the track. The only problems I ever had was launching the car without blowing the tires off and making my FUBARed tranny go into the right gear.
I just remembered you guys in Cali have that sh!tty 91 octane gas. Find a local place that sells 100 octane racing gas and carry a few gallons with you in a separate tank. If you have to use leaded gas thats fine too. Just use enough to get by then fill up your tank with unleaded gas as soon as you leave the track.
Old Jun 29, 2003 | 12:39 AM
Larrio's Avatar
The Definitive AE Master
your track times seem to be within the general E/T's for so cal tracks. The SC and N20 guys here run times all over the 14's around here due to the low quality tracks and high temperatures.
Kloogy ran his 14.7 at fontana
Old Jun 29, 2003 | 01:52 AM
2001SE's Avatar
its too hot man. 87 degrees is way to hot
you need to find a nice track with 60 degrees...around that, the lower you go the faster you'll go
Old Jun 29, 2003 | 02:07 AM
KLOOGY's Avatar
L33t BMW Drivah
When I ran my Stang at Englishtown, it was so nice,.... these tracks here all blow monkey ***** !
Old Jun 29, 2003 | 02:09 AM
Larrio's Avatar
too hard to get that type of temps here in socal. The tracks close down in the winter too for some reason even though there is no snow.
Old Jun 29, 2003 | 10:10 AM
2K2_6spd's Avatar
Sounds like the knock sensor was pulling timing, because you were detonating. You should prolly back off of the juice a little, and get a dyno tune with A/F before you try again, otherwise you'll have some of these.......
Old Jun 29, 2003 | 10:24 AM
MaximaMan77's Avatar
Thats what I was thinking, knock sensor.
Doesn't Jim run 115 octane when he does his runs?
Old Jun 29, 2003 | 11:27 AM
Eat Naaawwwzzzzz
that doesnt look too pretty
I want to dyno but i couldnt find a fwd around here.. I need to look better..
it it was that knock sensor, wouldnt I have heard knocking and pinging? Some detonation?
I experienced none of that..
maximaman777, jim actually hs a separate 1 gallon fuel cell with 113 octane.. I was running 91 like a dumbasz, I had my octane booster, but forgot to put it in.
Old Jun 29, 2003 | 11:36 AM
SR20DEN's Avatar
VQ Wizard
So do I. 100 unleaded or 110 leaded
Old Jun 29, 2003 | 03:39 PM
2K2_6spd's Avatar
You won't hear detonation, they call it the silent killer. I never knew my car was injured until I pulled the heads off. I knew I had a problem after a bad night at the track, but I couldn't figure it out.
Old Jun 29, 2003 | 07:09 PM
Wont kerosene work also. It's cheaper that octane booster and if you go to the track with a 1/4 tank of gas you could add a gallon of kerosene to it. Then when you leave hit the first gas station and fill up. I believe there are a few pages that have good info on doing this. I'll search and post some links.
I was wrong about kerosene. But see my post below for more info.
Old Jun 29, 2003 | 07:21 PM
wantasupra3's Avatar
Make the car lighter!
Old Jun 29, 2003 | 07:23 PM
Here are a few links.
http://au.geocities.com/ozbrick850/e...taneboost.html
http://www.team.net/sol/tech/octane_b.html
http://www.techweasel.com/articles/octane.htm
http://www.angelfire.com/ar/dw42/tech/octane.htm Good info on this one but popups
http://www.prime-mover.org/Engines/G...es/octane.html
and lastly here is my Yahoo search results.
Old Jun 30, 2003 | 08:18 PM
Eat Naaawwwzzzzz
if I used 30% mixture of Toulene,
what are the disadvantages to using this octane booster?
Old Jun 30, 2003 | 08:19 PM
2K2_6spd's Avatar
I used toulene for years on the bottle, only blew it up when I didn't use it
Old Jun 30, 2003 | 08:40 PM
HitManSE's Avatar
Dave were can we get it here locally??? How large of a quanity is required to puchase? 50gal drum? or the smaller 3gal is availible locally?
Old Jun 30, 2003 | 08:42 PM
2K2_6spd's Avatar
I used to get a 5 gal drum at the color wheel in Mesa, for $25.00, and mix it 1 gal to 10 gal of 91. That gets you about 94 octane.
Old Jul 1, 2003 | 12:29 AM
HitManSE's Avatar
Not bad...I think ill make a note of that
Old Jul 1, 2003 | 07:35 AM
[maxi-overdose]'s Avatar
what do you see on the heads? Do you have pictures of the damage? I know that EGT will be able to indicate detonation and right after it happened, the EGT will drop. Do you notice that too? thx
Team STILLEN
Aug 10, 2015 04:29 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
