Turn signals not working
Old Jun 29, 2003 | 08:40 PM
alexrovner's Avatar
Did any one experience any problems with turn signals not working?
My car has the strangest problem:
Both the turn signals and emergency blinkers do not work. But if i turn on the emergency blinkers for about 3 min.... they start working. When i turn them off and turn them back in about 2 min... they dont work anymore.
The turn lamps them selfs work fine.... if i lock and unlock the car... the alarm flashes them with no problem!
Any ideas on what it can be?
Any input would be apreciated
Thank You
Old Jun 29, 2003 | 08:49 PM
scopium
maybe your blinker fuse is messed up... maxes have fuses up the ying yang.. if not that check the socket....and check the wiring...
if u have warranty take it to the dealer.... but make sure u put back your stock bulbs if you have changed them...
Old Jun 29, 2003 | 09:16 PM
jeremysride2000's Avatar
disconnect and reconnect the harness to your hazard lights.. there is probably a loose connection there..
Old Jun 30, 2003 | 02:01 AM
chinaonnitrous1's Avatar
Jeremysride2000 is right..if the hazard is unplugged it will wrek havoc on your turn signals.
Old Feb 29, 2008 | 04:05 PM
colo's Avatar
I'm having a similar problem. My turn signals and my hazard don't work at all. I've checked the fuses and they are all good.
By the way, I'm new to this forum. I've been reading a few of your threads and i think you guys are great......
trasmadean
Feb 1, 2017 08:20 PM
03VQMAX
Oct 2, 2016 09:36 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
beboski
Aug 16, 2015 05:23 PM
kenc15
Aug 5, 2015 08:29 AM
