"HomeLink" question...
Old Jun 30, 2003 | 12:43 PM
02SEinStL's Avatar
This is driving me nuts...
I have followed the EXACT instructions to program it like 3 times, and the little red light flashes just like the card says it should, yet it has yet to open my garage door. Is there some trick I am missing?
Old Jun 30, 2003 | 12:46 PM
cichlidcity's Avatar
Re: "HomeLink" question...
I didn't have any problems... Is the remote for the garage low on juice or not held close enough or too close?
Old Jun 30, 2003 | 12:49 PM
BiggD23
It took me a few tries to get mine working right. When you say the red light flashes...is it flashing really quick? IIRC it should flash really quick for a few seconds to confirm that it got the frequency. I tried a bunch of different ways of pointing my existing receiver at the Homelink one, eventually I got it by holding it literally 2" away from the sun visor and I already had the button on it held in when I started holding the 2 Homelink buttons.
Padsy's Avatar
Boost.....
If you have not already......try reading the opener manual. They often have specific instructions on "rolling" code openers....especially for use with homelink.
I know mine gave me fits for about 30 mins.
Old Jun 30, 2003 | 01:09 PM
releasedtruth's Avatar
rilla dope
Did mine this week, took about 45 seconds from start to finish, seemed to work fine for me
Old Jun 30, 2003 | 01:15 PM
02SEinStL's Avatar
Yeah the red light flashed just like it says it should, fast, slow, whatever it said it should do, it did. It shows a pic of how you should hold the remote right up against the visor, so that's what I did. I'll try & find the opener instructions, though - that's a good idea.
Old Jun 30, 2003 | 01:19 PM
Maximax2's Avatar
When I programmed mine, it took a while because my opener uses rolling codes. And IIRC, to program for these you actually have to push a button on the opener (not the remote), which puts it into a special programming mode.
Old Jun 30, 2003 | 01:20 PM
soundmike's Avatar
Very sound, Mike
Listen to Padsy & Maximax, even though the Max has it's own instructions - follow the opener's instructions.
I have a Genie Xcelerator and the instructions are almost the exact opposite of the Homelink on the Max.
IIRC, after resetting the Homelink (e.g. Page 2 of the instruction card) do the opposite of what it says. Press the Opener's learn button first - then the Homelink's.
Old Jun 30, 2003 | 10:00 PM
mike_bresnahan's Avatar
It took 2 people to program mine.
Me on ladder in garage holding in programming button on opener, wife in car pressing homelink button. Kind of a pain but that's what you have to do with rolling codes.
Programming the gate opener was much simpler - it didn't use a rolling code so I could follow the instructions that came with the Maxima.
Old Jul 1, 2003 | 05:44 AM
soundmike's Avatar
Very sound, Mike
I thought i'd need two people myself, but i instead parked the Max under the Garage door opener - opened the driver-side door and used the sill-area as my step-up to reach the opener with one hand and press the homelink button with another
Old Jul 1, 2003 | 05:54 AM
kcowden's Avatar
Mine was a pain in the *** also.... now it works but my new problem is that we have two garage doors and they have the same type of door opener. When i push the home link button both f***ing doors or close. Anyone have a solution to this ??????? Please help.
Old Jul 1, 2003 | 06:21 AM
soundmike's Avatar
Very sound, Mike
Reset both the homelink buttons and the garage door openers. Then re-assign one button on the homelink to one opener and another button for the other.
Old Jul 1, 2003 | 07:56 PM
FuPeg's Avatar
If you can't get it to work after repeated attempts, the Homelink may be faulty. Try to program it using your neighbors or relatives door opener. If it does not program that one, take it to a Nissan dealer and get it replaced under warranty like I did. They put in a new one and it works fine.
Old Jul 2, 2003 | 12:57 AM
lcf's Avatar
lcf
Does 'Homelink' have to be reprogrammed after the battery is disconnected?
Old Jul 4, 2003 | 05:19 PM
spta97's Avatar
I took my shoes off and opened the sunroof
Old Jul 4, 2003 | 09:35 PM
ojman's Avatar
I have a parking card to get into my building..I suppose Homelink won't replace taht will it? I don't think it's an RF signal - but I'm not sure how it works - magnetic maybe??
Old Jul 5, 2003 | 06:47 AM
soundmike's Avatar
Very sound, Mike
Most garages (e.g. apartments, etc) usually have an RF-type opener in conjunction with the parking cards.
Try asking the building management if they offer RF controllers you can borrow (usually for a monthly fee).
Old Jul 5, 2003 | 02:31 PM
wally9mm's Avatar
No...at least for an hour, that I how long I disconnected it and the Homelink retained the codes. Unlike the radio presets that required to be set again
ObsidianIce69
Nov 7, 2002 12:03 PM
Naughty
Dec 20, 2000 10:12 AM
Naughty
Dec 5, 2000 12:04 PM
