installing rsb - i have a question!
Re: installing rsb - i have a question!
Originally posted by badabing
How far apart should the bushings in the back (U-bolts) be set?
Thanks in advance!
- badabing -
Thanks in advance!
- badabing -
Re: Re: installing rsb - i have a question!
Originally posted by sloppymax
if it an addco bar, i put mine about an inch inward from the bend. some have moved them in further to keep the bracket from hitting a piece of the chassis but i bent the corner so it never hits.
Thanks! I'll try that.
Did you ever have to re-tighten any of the bolts? I have to drive 500 miles tomorrow and am a little worried about it...
Re: Re: Re: installing rsb - i have a question!
I tried tightening the nuts after about a week, and they hadn't noticeably loosened.
It's a good idea to check the bolts after installation. They wouldn't loosen a lot(if at all) after 500 miles. Can you check them after the drive?
I checked mine after about 700 miles and I had 1 bolt that needed about a half turn to tighten fully.
Originally posted by VQ35DE
Did any of you guys have any problems with the brake lines and the side brackets? If so explain what you did. THANKS
...If you are concerned about RSB bolts loosening over time then use a torque wrench during the initial install and tighten each bolt to 40 ft./lbs....
I used my torque wrench, I have had the Addco bar for a year now, and I have checked it every time I jack up the car to rotate my wheels (every 10,000 miles). It has NEVER been loose.
Good luck...
Good luck...
This is also supposed to increase the effect of the RSB (the trailing arm has less leverage, so can't twist the bar as much).
Distance - the farther apart they are the better the Sway bar works. Though even if they're close together it'll still work better than not having one at all.
Brake Lines and Clearance - I noticed if i installed the end's first before doing the beam portion, it was harder to install the bar. (Or was it the other way around?) In any case, try one or the other. Nothing needs to be taken out or apart to install the Addco.
Originally posted by Maximax2
Mike, isn't the progress bar adjustable by the distance of the TRAILING BAR brackets from the BAR END, not by the distance of the brackets on the multi-beam? Think that's what I remember from the How-To's and instructions...
Whew....well, it's done finally. It took me a while to understand where everything was supposed to go and then I started putting everything in place (btw, THANK YOU OLINCOLES for the excellent write up).
One problem....one of the u-bolts had a severely messed up thread. I tried to wrench through it but it just would not go. Then I had to take apart anything that I put together, put the wheels back on and drop the the car. I called custommaxima and they were nice and eager to help but did not have any replacement u-bolts. They instructed me to go to a Home Depot to get another u-bolt - which is what I did.
My first impression is not as "WOW" as it was after the FSTB installation. But maybe my trek through the twisties on the western PA Turnpike tomorrow will make me feel a little different.
- badabing -
- badabing -
Originally posted by Uconn411
Can U post a link to OLINCOLES writeup?
Here ya go.... http://forums.maxima.org/showthread....D+installation
Can't wait for my 500 mile drive tomorrow to put the RSB/FSTB combo to the test.
Originally posted by GMoney
Typically do you guys install the FSTB and RSB before installing shocks and springs? Is there any negative effects of NOT doing shocks and springs first??
dutch078
Wheels/Tires
08-03-2015 06:58 PM
