over heating problem
Old Jul 7, 2003 | 05:53 AM
jttaylor155
HELP!!! over heating problem
My Max is overheating. It started as soon as the weather got warmer here, up to 98 degrees. The temp gauge goes all the way up within 20 minutes of driving it, even faster if the air is on. There is plenty of coolant.
So what could be the problem? It seems that coolant is not moving through the engine block like it is supposed to? Is there a block in a line, a stuck thermostat?
Old Jul 7, 2003 | 06:45 AM
jttaylor155
anyone??
Old Jul 7, 2003 | 07:01 AM
jjames's Avatar
Originally posted by jttaylor155
anyone??
I'm guessing it's a stuck thermostat. Check your hoses to make sure coolant is flowing.
Old Jul 7, 2003 | 07:36 AM
jttaylor155
i will check that after work. does anyone know the best way to remove the thermostat?
Old Jul 7, 2003 | 08:40 AM
Cutler's Avatar
A haynes manual can be of great assistance. I have one here in fairfax if you would care to look at it.
Old Jul 7, 2003 | 08:54 AM
jjames's Avatar
I'm not a car "expert", but wouldn't the thermostat be accessible by removing the top, or in some cases the bottom radiator hose?
Old Jul 7, 2003 | 09:47 AM
jttaylor155
i didnt know there was a haynes for 5th generations yet, i have looked around. where do you live? i may come check yours out.
Old Jul 7, 2003 | 10:05 AM
Cutler's Avatar
Fairfax off of West Ox road. PM me and I can give you directions
Old Jul 7, 2003 | 10:07 AM
FrankTheBunny's Avatar
This may not help at all, but my last car was a 94 Corolla and I had the same problem in that. It turned out to be my water pump was leaking and not doing it's job.
If you open the hood after it happens, does it seem to be hotter than usual? I realize that hot is hot on a 98 degree day, but if your engine is really over heating then I think you'd be able to notice the jump in temp.
Just some thoughts, I'm far from a mechanic.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
slowlifer
Sep 8, 2015 05:53 AM
