Frankencar pipe is in.......WOW
Old Jul 8, 2003 | 01:11 PM
MaxVader's Avatar
I just finished the install, about 1 hour and all I can say is WOW!!! When I first started the car I heard more air sucking in (like a real vacuum), I knew then that was a sign of things to come. Got on the street at normal acceleration and it sound great. BUT, when I finally got it at WIDE OPEN THROTTLE, THE CAR SOUNDED MAD AS HELL AND PULLED LIKE HELL. IT ACTUALLY SCARED ME!!! LOL. Overal its well worth the money and the time it takes to get to you! If your thinking about an intake Frankencar is the way to go!
Old Jul 8, 2003 | 03:00 PM
lcf's Avatar
lcf
Old Jul 8, 2003 | 03:05 PM
scmaxima2k's Avatar
Did you have any problems installing it. My friend did this on his 2K max and the midpipe was sagging really bad since he couldnt use the stillen brackets. Can you post some pics or something because Im thinking about doing this too cuz I love the sound it makes. Also, does it whistle at all? I love how my stillen whistles .
-Steve
Old Jul 8, 2003 | 03:08 PM
PCGuRu2K's Avatar
-Steve
Did your friend use the bracket from Frankencar?
If you want the wistle then get a blower
Old Jul 8, 2003 | 03:11 PM
MaxSE03's Avatar
Awesome......sounds like you like. I still like mine after almost a year. Just watch out for that right foot!!
Old Jul 8, 2003 | 05:20 PM
92 SE-R 02 SE
I used it, i broke it last week! Its weak!!
It still sounds so awesome though!
Old Jul 8, 2003 | 06:19 PM
Pir8 97's Avatar
-Steve
Here's a pic of my 2k. I need to push it in some but I don't have a bracket to brace it so I'm going to wait... don't want to screw up the MAF
I don't know about a whistle but the vaccuum sounds are very pronounced. Its not a constant sound, but it is kinda cool.
Old Jul 8, 2003 | 06:51 PM
00MaxSE's Avatar
Pointy Elbows
Yup, that's the exact position that mine is in, but I used the bracket and had to zip tie it to the bolt hole by the strut tower, because it wouldn't reach. No whistle here, just a deep roaaarrr!
Old Jul 9, 2003 | 09:43 AM
MaxVader's Avatar
Sure I can post some pics need to recharge the cam. But I was able to use the top Stillen bracket after all. I bent it alittle and turned it around. (pic will better explain) but its not sagging at all. I did not even get a bracket from Frankencar but even if I didn't have the stillen intake the Couplers would have been enough. They were tough *** leather to put on!
MaxVader's Avatar
Sure I can post some pics need to recharge the cam. But I was able to use the top Stillen bracket after all. I bent it alittle and turned it around. (pic will better explain) but its not sagging at all. I did not even get a bracket from Frankencar but even if I didn't have the stillen intake the Couplers would have been enough. They were tough as leather to put on!
Old Jul 9, 2003 | 10:12 AM
Shift_VQ's Avatar
I just installed my frankencar last week but i broke one of the tubes for my breather or vacuum lines whatever you call it. the midpipe is ****ty quality and just broke...wtf So I siliconed the hole it made and then just cut a hole in my main breather tube and siliconed it to that...it works but looks sloppy, also they should have made those tubes at an angle. do you think ill have any problems down the road? Also it seems that my frankencar got quieter, maybe I just got used to it though.
Old Jul 9, 2003 | 06:42 PM
Pir8 97's Avatar
Yikes! Have you contacted Frankencar? I know they are hard to get up with but since its so new they may send you a new midpipe... or give you a discount on one. Ask them to send you a new one and put out a call tag to pick up the broken one (after the new is installed). They may be able to reuse the old one (if its worth the effort to them). I'm afraid the silicone will give over time and allow the vaccuum to suck in debris.
Old Jul 11, 2003 | 08:06 AM
00MaxSE's Avatar
Pointy Elbows
Did anyone get stickers with theirs? I didn't get any!
Old Jul 11, 2003 | 12:16 PM
clipse's Avatar
Has anyone noticed a s slight bog when the car is idling???
Does the outside temperature/engine bay temperature have effect on this???
Old Jul 11, 2003 | 02:58 PM
acMAX's Avatar
i got a silver frankencar midpipe (used in conunction with JWT pop) back when they first came out and I still love it.....
but now I'm kinda wanting a turbo
Old Jul 11, 2003 | 10:42 PM
MaxVader's Avatar
"clipse" When I first hit the gas after startup Im get a slight bog. but thats it.
"00MaxSE" I got stickers with mine. its posted on the site that all shipments come with stickers.
Old Jul 11, 2003 | 11:09 PM
Loe max's Avatar
Mine broke when it was on the car after a couple weeks. I just repainted it and so far its holding in there.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
