condensation..........
Old Jul 15, 2003 | 02:48 PM
defconmax03's Avatar
I HAVE THE FRONT CLEAR BUMPER LIGHTS AND THE DRIVER SIDE HAS CONDENSATION IN IT. AND I BOUGHT THEM 3 TIMES FROM CUSTOM MAXIMA and all 3 times they have condensation and the rear bumper lights dont fit the molding isnt right, does anyone know where i can get a perfect fit and no condensation
THANKS
DEFCON
Old Jul 15, 2003 | 02:58 PM
BiggD23
First, let me just say that "the search is your friend"....this has been covered 1000 times already.
- You need to re-seal the clear corners around the edges with silicone otherwise you will probably get condensation. A tube of clear silicone will cost you about $2. There is no need to keep re-buying them, you could have just dried the first set out and re-sealed them.
- The reason the back ones don't fit right is probably because you didn't take the 3 little rubber squares off the back of the stock corners and glue them on the clears. They don't come with them for some reason and without them the clears have some wiggle to them.
Old Jul 15, 2003 | 03:06 PM
OK MY FRIEND
i will search to avoid the rath lol
no i know to search i just wanted to get peoples opinion and as for the sealing with silicone i will try it , its just that im **** when it comes to things on my whip and i want ish perfect ya know?
next time i'll "search"
-defcon
Old Jul 15, 2003 | 03:10 PM
Maximum Velocity's Avatar
Re: condensation..........
THANKS
DEFCON
Check in the FAQ section about the procedure to remove condensation. Or to prep your NEW lenses to prevent condensation before you put them on.
Old Jul 15, 2003 | 03:32 PM
BiggD23
OK MY FRIEND
-defcon
I hear ya, I'm the same way. If you give the silicone overnight to dry you dont have anything to worry about, it won't come off on the car or anything like that. And you can't see it from the outside. It took me like 3 coats to get a good seal though, every time it dries little bubbles form that air and water could get through so I had to keep filling those in. A real PITA. But no condensation. Good luck.
