Recharge air conditioning
Old Jul 21, 2003 | 07:15 AM
Miata32's Avatar
Hello All,
I was wondering if anyone has recharged their own air conditioning using those do-it-yourself kits on a 5th generation Maxima? If so, did it work well and how did you do it? Thank you.
Tri
Old Jul 21, 2003 | 09:12 AM
Magellan's Avatar
If you need recharging on a 5th gen Maxima, I would suspect a leak somewhere. In that case I would take it to an A/C shop or Nissan dealer that can find and correct it. But if your'e getting around 50-60 degrees out of the registers I would just leave it alone.
Old Jul 21, 2003 | 03:41 PM
lcf's Avatar
lcf
I thought they made those self-chargers illegal bc they releases CFC's into the atmosphere?
Old Jul 21, 2003 | 04:51 PM
vsamoylov
go to walmart and get the recharge kit which includes the hose and a bottle of coolant. Works pretty good.
Old Jul 21, 2003 | 06:08 PM
jonbth's Avatar
The new freon is ozone friendly and not illegal for the backyard mechanic.
Old Jul 21, 2003 | 08:21 PM
Miata32's Avatar
How to do it
Do you have any instructions on how to do it? Where to connect the bottle hose to the engine hose? I know I am using the wrong terms but I think you get the idea. Thanks.
Old Jul 22, 2003 | 11:15 AM
jonbth's Avatar
It has to be hooked to the low pressure side. I think the fittings are different and you won't be able to hook it up wrong. Look for the thicker of the two A/C hoses. The fittings should be easily accessable. Be careful not to put too much freon in. I beleive too much and it won't get cold. Just add little at a time and test it out. I think the whole system holds about a pound, which is one can.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
maxima297
Sep 24, 2015 01:18 PM
msellas
Sep 23, 2015 09:16 PM
conansriver
Sep 11, 2015 10:26 AM
