did anyone else have problems installing K&N drop in?
Old Feb 4, 2001 | 07:17 PM
psing23's Avatar
i dunno i just bought myself the drop in filter and i was putting it in and it couldnt get it in right... i really had to muscle the cover closed... i finally did get it closed but is that the way it is supposed to be?
Old Feb 4, 2001 | 07:19 PM
Paul6speed's Avatar
Yeah... it's a tough fit. If you use the included spacers, it will fit better. If you didn't get the spacers, you can call K & N and they'll send them to you.
Old Feb 4, 2001 | 07:22 PM
psing23's Avatar
were the spacers supposed to be in the box with the filter? i didnt get it... how will it make it better if it was tight already wouldnt the spacers just make it even tighter? well i did get it in so i guess i dont need them right?
Old Feb 4, 2001 | 07:26 PM
Paul6speed's Avatar
part# 33-2031-2 = foam spacers included
part# 33-2031-1 = no spacers, but same filter as 4th gen
TexMaximum's Avatar
NO NO NO....
No, you are stuffing it in the wrong way/side or you got a filter that’s too big.. Try your Stock one again, and you'll see which way the K&N fits and what I’m talking about.
The only problem is on that side, its to loose, and on the other side you have too stuff it, but that’s not the correct side.
So you need some spacers. You see, That filter is a standard size, even fits some GM cars and K&N figured it was close enough then to make a whole new filter for just a few cm. Anyhow, the spacers are left out sometimes, all it is is that sticky one sided felt like strip people put around home doors for a better seal. Very cheap, get a strip from home base. One strip on each side of the air filter tray will hold the filter snug on the CORRECT side.
Old Feb 4, 2001 | 07:35 PM
Paul6speed's Avatar
TexMaximum
I've taken mine out a dozen times... and it's not a perfect fit. The stock filter goes in and out quite easily. I found that using the spacers, it was a little easier to install the filter. Psing, make sure you are turning the filter in the right direction, but I assume you are already doing that.
Old Feb 4, 2001 | 07:36 PM
psing23's Avatar
well i put it in the same way as the stock filter was in... i got the part # 33-2031-2
but i didnt see any spacers inside... i dunno... i got it closed and it seems like its snug... so i dunno what to do...
Old Feb 4, 2001 | 07:58 PM
Paul6speed's Avatar
Psing
You got it in and it's snug. I would just leave it. Next time you have to put it back in, it will probably go in a little easier.
Old Feb 4, 2001 | 08:04 PM
psing23's Avatar
ye prob... TexMaximum i think i figured out what u talkin about... no i am putting it in the right way... its not hard to put it in that holder thingie... yea it is loose in there... its hard to get the snaps closed ontop... much harder than stock but i looked at it and the stock gasket thingie on the filter is thinner than the K&N one.. and its softer on the stock one which is prob the reason that its harder to close the K&N one... well atleast i know its not me then and others came accross this too... im happy its finally in and now the next step is putting the OSCAI in... guess its gonna wait till next weekend...
Old Feb 4, 2001 | 09:07 PM
punkdork's Avatar
I just got one today. Used.. $30 off of Jeff92se. I was gonna sell his bro my popcharger but it won't fit a 3rd gen. Funny thin is, the panel was from his 3rd gen.
Old Feb 4, 2001 | 09:19 PM
psing23's Avatar
ye tahts cool... i guess u lucked out with that filter... only $30 is great.. i just payed $54 for mine today at autozone...
Lakersallday24
Nov 7, 2024 07:31 PM
dank4us
34
Jun 10, 2024 03:45 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
