03 OIL Change
Old Jul 22, 2003 | 10:17 AM
Roymg's Avatar
03 OIL Change
Changing oil in my max 94 is a cinch. However in my new 03 I noticed there is now a shroud underneith the pan hiding the filter.. What have u self doers done about this?. Do u just take the shourd off, as my service manager told me, or is there another way? I guess my question is "do u have to remove the shroud to get to the filter"?
Old Jul 22, 2003 | 10:21 AM
kratz74's Avatar
no just flex the plastic shroud (pull it out) and reach in there. It won't hurt it. It flexes quite a bit. Have done about 40 oil changes on Maxes like this and never a problem.
Old Jul 22, 2003 | 10:56 AM
BiggD23
It's held on by 4 screws...2 normal ones and 2 push screws. I take the 2 normal screws and the bottom push screw out, leaving only the top push screw in. This holds the shroud in place but still allows you to pull it forward and get to the oil filter.
Old Jul 23, 2003 | 10:47 AM
Roymg's Avatar
Okay, will give it a shot..thanks much.
Old Jul 23, 2003 | 01:30 PM
jonbth's Avatar
The filter is small enough to just reach up and take it out. No need to remove the shroud.
Old Jul 23, 2003 | 01:44 PM
BiggD23
Taking it off isn't the problem...putting the new one on blindly is. It takes 30 seconds to remove the screws and pull the shroud out instead of trying to feel your way to getting the filter on right.
Old Jul 23, 2003 | 01:58 PM
bigdo26's Avatar
i've just bent the plastic to get at it. puttin the new one on blind is a bit of a pain tho, I will admit. maybe i'll take the panel off next time.
Old Jul 23, 2003 | 02:08 PM
asu174's Avatar
Clay Aiken has fancy genitals
I have never removed any screws. The panel flexes just fine. I have never had any trouble putting the filter back in either.
Old Jul 23, 2003 | 02:33 PM
Y2KSESteve's Avatar
I just move the panel aside. Get a light under your car and its much easier to put the filter on.
Old Jul 23, 2003 | 02:42 PM
BigFly_2K2SE's Avatar
Old Jul 23, 2003 | 04:18 PM
SR20DEN's Avatar
VQ Wizard
Removing the shrould to change the filter on a VQ =
JoshG
51
Sep 21, 2015 10:41 PM
f.matejaiii
Sep 21, 2015 12:09 PM
97_GXE
20
Sep 17, 2015 08:12 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
