4th gen coil-overs on 5th gen??
Old Jul 24, 2003 | 08:27 PM
dblrr900's Avatar
I found a good deal on 4th Gen Coil-overs. Will they fit on a 5th gen??
I know I have read on here people doing stuff with 4th gen suspension parts. I just need to know if these will work and if anyone has done it with success.
ASU? RobAE?
Old Jul 24, 2003 | 10:47 PM
bsetiawan's Avatar
Re: 4th gen coil-overs on 5th gen??
Is this a full coilover or just the springs like the Ground Control ? If it's a full coilover, the fronts won't fit cause the mounting points at the knuckle is different.
Old Jul 24, 2003 | 11:26 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
yep, like above....mounting brackets wont fit for the front....
backs will though
Old Jul 25, 2003 | 06:11 AM
dblrr900's Avatar
NO. Just springs. Will they fit?
Old Jul 25, 2003 | 06:17 AM
PCGuRu2K's Avatar
If you get the AGX's and modify them to fit the 5thgen then yeah you can use 4thgen gc's..
Old Jul 25, 2003 | 06:26 AM
dblrr900's Avatar
OK. I knew about the strut work that had to be done. I am not picking up struts right now, just the GCs..... will they fit on my stock struts?
Old Jul 25, 2003 | 06:58 AM
PCGuRu2K's Avatar
Nope.. It'll sit funny on the pirch..
Old Jul 25, 2003 | 07:16 AM
asu174's Avatar
Clay Aiken has fancy genitals
Sorry, it ain't gonna work with stock struts. Expect a ton of noise and problems.
Old Jul 25, 2003 | 08:17 AM
dblrr900's Avatar
Thanks dood. I was kinda waiting on you, because I know you have been downthis road a couple times now.
Old Jul 25, 2003 | 08:37 AM
chris'smax's Avatar
i have a set of progress springs which i think are designed to fit both fourth and fifth gen. or are they?
Old Jul 25, 2003 | 09:01 AM
Luquire's Avatar
The progress springs are meant to fit both 4th and 5th i think. The reason is b/c when you order them the part number for the 5th and 4th gens are the same. Go to cattman.com and you can see the part numbers
MAXSE5SPD
Sep 17, 2022 04:00 AM
ef9
Sep 29, 2015 11:29 PM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
