For Guys who had questions on changeing Manual tranny Fluid here are pics
Old Feb 5, 2001 | 07:00 AM
PIONEER's Avatar
In the order I do it in.
This is the fill Plug, Unscrew that first ..
<img src ="http://www.geocities.com/nismorg/Transmisson/fillplug.jpg">
<BR>
<img src ="http://www.geocities.com/nismorg/Transmisson/fillplugopen.jpg">
<BR>
Drain Port/sensor, This is where the speedo sensor is, unscrew that using a 10mm socket and "GENTLY" pull it out "SLOWLY" b/c there's a lot of oil on the other side and its eager to come out
<img src ="http://www.geocities.com/nismorg/Transmisson/drainplug.jpg">
<BR>
LIKE SO
<img src ="http://www.geocities.com/nismorg/Transmisson/drainingoil.jpg">
<BR>
Old Feb 5, 2001 | 07:02 AM
PIONEER's Avatar
This is what the speedo sensor looks like.
<img src ="http://www.geocities.com/nismorg/Transmisson/drainplugsensor.jpg">
<BR>
Now this is the kicker. Since I got my factory Air Box removed, I use a funnell with a long pipeing and refill the oil from the top. B4 When I had my car stock I had a Pump that I had purchased from pep boys for like $5 and I use to fill it from the bottom. it takes about 4 1/4 Qts of oil. but the best way to tell when its full is it starts to leak out of the fill hole. Good luck guys.
<img src ="http://www.geocities.com/nismorg/Transmisson/addingnewoil.jpg">
Old Feb 5, 2001 | 10:24 AM
RussMaxManiac
You know your not supose to remove that SPEEDO sensor out. There is a drain hole on that transmission already there for you. It is right next to the shift linkage on that side. LOL, oh well
Old Feb 5, 2001 | 10:53 AM
PIONEER's Avatar
Russ I'm not sure about the drain plug but I know the tranny sensor on the 2K is not the same as the 4th gen. the 4th Gen had teeth behind the sensor, the 2K is just a electronic switch. O well. thats how I've always done it.
Ray229Harris
Sep 16, 2015 08:16 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
jholley
Aug 11, 2015 09:38 AM
RealityCheck
Aug 5, 2015 06:18 AM
Jcof88
Aug 3, 2015 10:43 PM
