maintenance question
Old Aug 1, 2003 | 03:07 PM
Maxnut's Avatar
I have a 2003 GLE. I took it to the dealer today for an oil change and for brake judder. I have 18k miles and the dealer highly recommended the 15k mile maint. Is the 15k scheduled maint. worth the cost ($160) or would I be waisting money? They also told me the rotors were somewhat warped, so they turned them, they did not replace the pads, they said they still had 10k miles left. I am a little concerned that they did not replace the pads, I have always heard that every time the rotors are turned you should change pads. Is there any truth to this? The brakes do feel much smoother. Thanks.
Old Aug 1, 2003 | 03:15 PM
saxdogg's Avatar
It's usually good to replace the pads with a rotor resurface ( or new rotors), but good luck. It seems some people have bad luck either way. Mine has 16k and the brakes are still silky smooth.
The 15k service probably includes things you can do yourself, like a visual check of everything and a new microfilter. Get your tires rotated for $10 with a coupon, and change the oil yourself and put in MOBIL 1!
ARFF
Old Aug 1, 2003 | 03:26 PM
scopium
dont ever take your car to the dealer ship again... u can get your 15k maint.. somewhere else for alot cheaper... and trust me your rotors are not warped .... i got 33k on my 2k1 max and they told me the same thing...
your can get it resurfaced for like 20 bukcs somewhere else...
F U C K the dealer
Old Aug 1, 2003 | 03:54 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
F U C K the dealer
mine were warped at 9k. when i braked from anything over around 55 with moderate pedal pressure the wheel would shake violently. they repalced the pads and turned the rotors for free. im at 31k now and they were acting up again so they replaced the rotors but kept the same pads. the 15k is not worth it. just have the oil changed and tires rotated if you are due.
Old Aug 1, 2003 | 04:46 PM
MAKSYMALNY
I wouldn't say "F" the dealer... I take both of my SE's to the dealer for service (although the dealer I go to has a 'preferred card' that costs $80 and gives you 12 free oil changes and 10% off parts and labor for 3 years)... you just have to be smart about it.
I changed the brake pads all around on my 2000 SE, but I accidentally introduced air into the system, so I had low, low pressure. I took it to the dealer, knowing that all I needed was for them to bleed the brakes for me. She gave me the run around about "we have to check for caliper damage" and "you should resurface the rotors" blah blah ... I said "hey, look, I told you to just bleed the brakes, so bleed them".
She came back to me and said that if I wanted the rotors turned it would be $180 a pair (!!!)... I said "oh, well, if I NEED that, I can have Midas do it for $20"... quite a difference!
The dealer does good work, you just have to be smart about WHAT work to let them do, and to shop around for other places when necessary.
And BTW, the 15K mile service isn't a bad deal... and is worth it for them to check your car and ensure everything is ok and running smooth.
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
